Speaker Enclosures
I wish I couldve made them a little lower, but then the 6x9s wouldnt have fit.
I got the carpet at a local stereo shop.
Karl
Sorry, I wasn't specific there. I meant the carpet in the Jeep, not the carpet on the speaker boxes. (of course, you might have also gotten your regular carpet at the stereo shop....)
Thanks! Now if you'll just post up all the dimensions and templates on your speaker box components we'll all be happy......
I forgot to post the dimensions. Sorry.
The top and bottom measure: 6 1/4 x 11 x 9 1/4 x 10 1/2 inches
Height is 7 inches.
Front piece is 11x 7
Back piece is 10 1/2 x 7
Top and bottom are 5 1/4 x 8 1/4 x 11 x 10 1/2
Sides are 6 x 8 1/4
If this doesnt makes sense let me know. I used 1/2 wood.
Karl
Thanks! Now to go cut off a finger trying to cut some plywood.
Any updates on any of these speaker boxes? Revisiting the subject.....
Unfortunately no... it looks like I might be relocating back to the States shortly so with luck I can finally wrap this project up!
I'm going to try a different approach to putting some 6" x 9" speakers in with the half cab. I've gotten a fiberglass bulkhead that I'm going to build the speakers and maybe an amp into with a bump out into the bed. It's going to be a winter project.
I leave my bulkhead in when the half cab comes off. Made 2 6x9 boxes and attached to the upper part of the bulkhead. Works with the seats I have. Amp is under the driver seat. Works well for what I have invested.
When I pull the half cab, I take out the bulkhead and put in a rear seat. I've had a set of box speakers in there, but it takes almost all of the small space behind the seats. I have an amp mounted to the bottom side of the console. I'm trying to recover that space back there, maybe even add an extra compartment with an OEM glovebox door.
Going to be testing my fiberglass skills.
I leave my bulkhead in all the time and have 5" round speakers mounted in it behind the front seats. I used 6" sewer pipe caps for speaker boxes and they are water tight
Sounds good. Do you have any pictures? I like the idea of the sewer caps.
I realize cutting into a bulkhead is a little sacrilegious but has anyone thought of that? You could fab up some enclosures on the bed side and all you'd have protruding into the passenger compartment would be the speaker flange and grille??
Sent from my SM-N930V
My bulkhead was only about a 5 out of 10. It had a few dents and bangs in it. I also had to shorten it about an inch to fit properly in the fibreglass tub. My scrambler look good I think but it is very far from a concours cobble beach vehicle.
I used Polk Audio Marine speakers. I bought a too large Sony Marine amp for my boat but could find anywhere to install it where it would fit. Had the same problem with the Scrambler. It would not fit any where you couldn't see it. It too is mounted to the bulkhead and covered by a piece of aluminum checker plate.
Nice work! Liking that half soft top too! :)
