AMC 401 build: Knocked one of my Bulltear pistons onto concrete. Now what?
JeepScrambler
CJ-oholic
Claflin
KS
Long story short, I am finally putting my 401 together after years of gathering parts and putting off the assembly. I started to assemble the engine and found out one of the camshaft bearings was not installed perfectly, causing the camshaft to not fully seat in the engine (tried my Engle and original cam, same result with both). This resulted in me having to take the crankshaft and piston/rods back out. Somehow in the process, idiot me knocked one of my custom Bulltear pistons off of my work bench onto the concrete floor below. This caused some slight pitting and rough spots on the top edge of the piston. I have only built a few engines so I was hoping someone with more experience or has come across something like this can help me shed some light on what to do next. There are a few other small imperfections (pits, etc) I'm assuming from casting/forging/valve relief cutting on the pistons so I was how big of a deal these pits and rough spots wound be?
Can I simply grind/polish the rough spots out, not worry about the slight pits, and run the piston with no adverse affects? Do I need to just order a whole new piston from Bulltear? I'm still pissed at myself for this...
Sent via signal flare
I would guess you are going to get different opinions here but I think it could be cleaned up and put back in assuming the piston is still round and the wrist pin and rod are not damaged. I have pulled Pistons out of engines that ran that looked far worse than that.
I agree: I'd clean it up and run it.
I say the same . I seen some crazy pistons worse then that . as long as the rings are not damaged and you will be fine . clean the ruff up .
Sent from my SM-N910P
Agreed. I'd be more concerned with damage to the rings.
I checked the rings out today and they are good; not a scuff on them.The piston only fell a couple feet and landed right on the edge so it missed the rings and connecting rod. Will polish the rough edges up and start going back together with it. I appreciate everyone's input!
