TJScrambler - Getting Started
I can see the finished product now. LOL
Be careful I removed the brackets under the front of the roll bar when I had my tub on my rotisserie and after I had it all together and mounted on the frame I had the body filler (skim coat) develope a crack (including through the paint). Took it down to metal and redid only to have happen again. Never cracked the metal of the tub. Did some snooping on the inside of the tub and found the rear edge of the pillar (inside tub) had separated and the crack was on the outside of the tub running along the pillar. Ended up using body panel adhesive to bond the pillar to the inside skin to lock it in. No problems since I did the fix.
Were you able to save the flares? Looking forward to seeing whats under the sliders.:popcorn:
The flares were saved... under the sliders is not too much, a small area on the driver side.
Sliders aren't beign removed until we get the new floors in place to stiffen it all back up.
PRE-SLIDER
That's good to hear, a good tub and will stiffen the tub. I'm just a worry wart on the flex of the tub, don't want to see someone have the hassle I had because of flex. Looking forward to the build.:thumbsup:
I made a couple of angle braces that bolt to factory CJ tub holes.
That should help. You'll be glad you did this when you take the slider off.
An x brace across that would also keep it from side movement.
Spoken from the mouth of the most interesting man in the world
I dont normally brace my rusty scrambler tub...
But when a bunch of wise men I don't know tell me to brace it... I go freakin overboard !!!
Seriously though. ... looking for feedback to my rigid 4 link braced scrambler
Cb
I think that will work. Good job.
P.S. think it's ok to take the slider off now. LMAO :)
You think being one of the most interesting guys in the world I wouldn't have been divorced three ficken times.
I can take it. LMAO
Well, when I see people ask for opinions on their roll cages the normal response is:
"It could use more triangulation" :rotfl:
That should hold it together quite well. Wish I would have thought of it.
I plan to take the sliders off today and hopefully rotate it around to get to the rear surgery.
Basically the rear body mounts are shot and I want to mount the rotissiere to it, but I need to replace that piece first, so
Sliders off
Rotate it
remove rear tailgate support structure and part of the rear floor
"Glue" it all back together
Re-combobulate the rotissiere to use the rear body mounts for a lot more balanced and easier spinnging
Then start the rear or front replacement, whatever seems to be in need first.
Plan in motion... sliders off first
Most of the day was spent trying to figure out the washing machine
Sheared off impeller shaft on the discharge pump
In today's segment titled lessons learned from the last build we make the rear tub support look like the oem. Extra drain holes as well as three for the wire loom
Progress... I suppose
Drilling spot welds. Heavy rust are has thick metal behind and no rust area has thin metal. Go figure
I mocked it up even though I now need a corner and don't have one
Cut out so much metal
And it didn't want to give it up. So much for the strength of rust
