TJScrambler - Getting Started
A new tub is 5000-6000 and is aftermarket and I have just seen/heard too many complaints about it.
I have about $500 into the tub as it sits.
New floors, new bed floors, new parts pieces will be probably $1500 and then the time.
So, it is cheaper to do it this way, but definitely not easier or less time consuming.
But, I am doing it and I will know it is done right and allows me to get weld thru primer in between all the panels and rust preventative measures... so I am happy about that.
I understand the satisfaction of doing it yourself, I did the same thing on my '81 CJ8 thats why I mentioned getting a new tub. Hour after hours of removing spot welds.
I missed a ton on this thread :eek: was there a call made on the grille/hood? I didn't want to throw up new input if you'd already decided ;)
We will go with the flat fenders and regular hood for this one... the commando hood will make in on the LJ or CJ6 :)
I kind of mentioned it above, but I don't have all the money yet to buy them along with the one cowl support I need and the step up piece, so next month I plan to buy the rest of the pieces/parts.
I have one extra one already from another tub and one of mine is in pretty good shape, the other is pretty bad... like 1/2 of this thing ran in salt and the other didn't.
http://www.classicent.com/products/jeep-wheelhouse-1981-1986
Looks like it's all coming together nicely. There's light in that tunnel! You may want to leave the poison spider rocker guards on while you swap in the floors initially. I think they would make nice braces for the tub in addition to whatever else you set up. Then once the floors are in you could remove them while you weld it all up.
Agreed... the plan is actually to leave the rockers on and put it on a rotisiere as well to do the job, we will see how that works out.
The rear section needs to be replaced as well where the tailgate bolts to, so it is a toss up to do that first or last as that is where the rotisiere will bolt to, so I have to figure that out as well.
I need another month or 2 to get the rest of the "floor funds" and "rotisier funds" though, so it will be a bit.
Brace it well. I found out when I put the tub on my home made rotisserie and removed the braces (under the roll bar). When I put it together I kept getting a fine crack on the drivers side of the tub (outside skin) running along the pillar. Would fix the skim coat of body filler and paint. It would sit over the summer and in the fall when I would get to it the crack was back. Found the pillar separated from the tub wall (when tub flexed on the rotisserie without the braces) and allowed the side to flex and crack the paint. Fixed the pillar and this fall when I looked all was good.:fingerscrossed:. Pics are in the build tread if interested. Learned a hell of a lesson.:cool:
This is how I braced mine and it's still not enough.
When I made my home made engine stand rotisserie I didn't use any braces and had no issues with flex. I used the body mount points front and rear so I had full access to the body surfaces all the way around. I set the body lower than the center of rotation by trial and error until I had the balance right where I could roll it without to much effort. 2 cheap engine stands from HF and some left over angle iron, and the old rear frame support. It worked
That's a nice stand but it looks like it's bowing in the middle. Have you measured the distance from the floor at the center pipe brace and then again at the casters. You may try supporting the center extensions with a set of swivel casters at the same height or even a bit higher than the end casters. That would apply a lifting force to the center and take the inward force off the body. Just a thought.
Roll the body 90 degrees an take a measurement at the center of the extension pipe. I'll bet the distance changes from when the body is level.
