OK... I know I have to get better pictures, but this is how it went down yesterday.
I went to the Dr. to get the results of the blood work and I was OK'ed for another year... so a celebratory Switchback was in order... also, my fenders came in as well.
Did some horsetrading and received a set of TNT custom 3" lip built in flat fenders in the mail yesterday.
Was interested and excited to try them out so I went to put them on and found out a few things.
First, they are nicely built fenders... second, they have much larger opening, so the Poison Spyder rock rails don't mesh to well.
So, I had to remove the rocker knockers.
So, before I ran out of time, I undid the grille/cowl supports and put the new fender in place and had to move up the front grille so it would be level and finally got it on there, but as I said, I had to remove the rocker knockers and I also had to remove the charcoal canister as well as some broken brake lines from the manual master cylinder.
All in all they look great, and would work great on a normal setup with a normal hood, but the "wings" from the commando lights and the commando hood present a challenge.
It is hard to see, but they overhand the flat fender a bit. It is because the flat fender doesn't come straight out at a 90 degree angle for the full bend, it starts to taper... again, great for a stock hood, but not so much for this application.
So, I am not sure what I am going to do here. I have to get the hood on and take the lights out and secure the wings so they are perfectly straight and get the other fender on there and see how it all looks and how much the overhang is. I guess I could cut the fenders and extend them, but I wasn't looking to modify them too much.
I guess the fenders could go on the wheeling Jeep, but I really wanted to put them on the Scrambler with the Commando nose, as from the side it would look kind of cut off flat and not extended into the front frame area. It would more room for the winch and other front end accessories and not have the overhang of the fender.
Again, this is all preliminary, so I have to get more done before I make more decisions, but all in all, I have the parts, now I just need the time!
