TJScrambler - Getting Started
The seat belt bolts were the absolute worse... I couldn't get them out... heat, spray, didn't matter... I ended up cutting them off on the bottom and the heating them until they were almost melted, hit them with a hammer and the torx bit and the sprayed some WD40 in there and worked it back and forth, tightening and loosing until it gave it up to me.
It took a while, but all the bolts are out.
I just realized that the rear tires are swapped... or the front are, but I have never had directional tires... too funny.
This is what happens when you take them off one vehicle in one garage and put them on in another garage and midway through, your floor jack gives it up cause you broke a tiny u-joint and you have to use channel lock to loosen it!
I HATE sat belt bolts!
And I noticed the tire direction issue but assumed they were just on temporarily :D
Been working on the Reclamation project a lot... it is mostly done.
The scary lift is off, and it has been returned to a more stock setup.
I drove it a little bit last night in the driveway, still some adjustments on the clutch and a few minor things left and then I can get to working on the wheels to swap on there... picked up some General Grabber AT2 last night for a good price. Stripping the waggies and painting them hopefully on Sunday.
I am going to look at a Jeep collection tomorrow, no ideas what is there and what is for sale, but if there is anything neat, I will post it up here.
Latest
http://certifiablejeep.com/Reclamation/reclamation5.php
Older
http://certifiablejeep.com/Reclamation/reclamation4.php
http://certifiablejeep.com/Reclamation/reclamation3.php
http://certifiablejeep.com/Reclamation/reclamation2.php
Dropped off the final piece of the puzzle to get mounted and balanced so I can move the CJ5 out of the shop...
It was my cell phone in the back of the truck an hour ago, sorry for the crappy pic quality.
A few updates... The Scrambler had some work done on it this weekend... the rear bumper is fully installed, was missing 4 bolts and had to drill them in the frame.
The door strikers were removed and replaced. the originals were so mangled, now the doors open/shut like butter.
The seats were installed. I had bases that had to be cleaned a bit and then they went on and went in. Kid sat in them and loved them... she said the red was great... I corrected her and said Garnet. She then proceeded to say the word Garnet like 50 times.
Pics to come of all the work, no time to post them yet.
I finished up the CJ5 as well, the new tires/wheels are on it and it should be heading home next weekend. I took it for a ride... ran good.
I even got my 7 out and drove it... it was cold, but I had to pick up another car seat for the little one and I had to make sure it would fit... it did!!! So I installed it and all is good!
Where did this shackles come from? I'm currentlymshopping for replacements.
Sent from my iPad
All the stuff for the CJ5 came from Quadratec... the Scrambler has Rubicon Expres 4.5" lift kit on it and the shackles came with to allow the springs to go from 2 to 2.5 in the front.
I put up some pictures of the door striker issues...
This was the original mangled one
and the installed YJ one
Everything shuts much much nicer now...
Complete build doc/pics (12 pages so far)
http://certifiablejeep.com/TJScrambler/tabscrambler12.php
This weekend I am going to have some time to work on it again... I am looking forward to it... the 15" of snow we had yesterday and all the plowing/shoveling makes me long to get out there and work on that instead... beer too!
Spy Shot... was playing around last night after packaging up a few eBay items I had to send out.
I came to the conclusion that my tub and frame combination was throwing off the test fitting.
Basically I have a grille coming in this week and will have the wings from them that I can then mount to fill in the spaces.
The issue however, is that the Matkins frame and the body are on blocks of wood at the moment, not on the body mounts.
And I think the thickness of the wood pieces are NOT the same as the body spacers, or in my case, a 1" Body Lift Kit I plan on running.
So, that, combined with the small piece of wood underneath the grille shell, it makes the body lower and the hood is not sitting flush.
Also, since it is just sitting on the blocks of wood, I am pretty sure the body is crooked by a tad bit.
So, I pretty much need to set the body in place here it will be and tighten it down and then the grille and then do it again.
Also complicating things is that I think I want to run TNT Customs Flat Fenders with the 3" flare
http://www.tntcustoms.com/jeep_tube_fenders/CJ/3inchflare.aspx
I say "complicating" because although I WANT to run them, I don't have $1K to spend right now on them.
So, best laid intentions, might have to wait a bit until I can sell more of my junk.
This should tie it in more together... still waiting on flat fenders as I think that will complete the look... also need to find a junk hood to cut up.
I got the wings from another grille that was beat up, so I didn't have to cut mine up.
This is what happens when you put your Jeep under a pine tree... I scrubbed and scrubbed for 20 minutes just to clean off from what it was to what it is now... pine sap, sunned into place over many many years.. stuff is worse than glue, you can just move it around a bit and it doesn't really want to come off.
OK... I know I have to get better pictures, but this is how it went down yesterday.
I went to the Dr. to get the results of the blood work and I was OK'ed for another year... so a celebratory Switchback was in order... also, my fenders came in as well.
Did some horsetrading and received a set of TNT custom 3" lip built in flat fenders in the mail yesterday.
Was interested and excited to try them out so I went to put them on and found out a few things.
First, they are nicely built fenders... second, they have much larger opening, so the Poison Spyder rock rails don't mesh to well.
So, I had to remove the rocker knockers.
So, before I ran out of time, I undid the grille/cowl supports and put the new fender in place and had to move up the front grille so it would be level and finally got it on there, but as I said, I had to remove the rocker knockers and I also had to remove the charcoal canister as well as some broken brake lines from the manual master cylinder.
All in all they look great, and would work great on a normal setup with a normal hood, but the "wings" from the commando lights and the commando hood present a challenge.
It is hard to see, but they overhand the flat fender a bit. It is because the flat fender doesn't come straight out at a 90 degree angle for the full bend, it starts to taper... again, great for a stock hood, but not so much for this application.
So, I am not sure what I am going to do here. I have to get the hood on and take the lights out and secure the wings so they are perfectly straight and get the other fender on there and see how it all looks and how much the overhang is. I guess I could cut the fenders and extend them, but I wasn't looking to modify them too much.
I guess the fenders could go on the wheeling Jeep, but I really wanted to put them on the Scrambler with the Commando nose, as from the side it would look kind of cut off flat and not extended into the front frame area. It would more room for the winch and other front end accessories and not have the overhang of the fender.
Again, this is all preliminary, so I have to get more done before I make more decisions, but all in all, I have the parts, now I just need the time!
can you angle them back a little and trim the hood to match?
I will post up a bunch of pics tonight... a new wrinkle in the mix makes me have to figure out if this is the way I want to go.
Well, the wrinkle that I mentioned is that I am not sure I like the look now that it is all together.
Here is a stock hood, flat fender combination:
And the commando setup on there:
The hood that is on there is damaged and bent, so it doesn't come down all the way on the flat fender setup for the commando nose, so the overhang isn't pronounced as it actually will be, but it is still there.
They both look cool and both setups have their pros and cons, but I am leaning towards stock as it looks better in my opinion. Without the actual tires it is hard to visualize on the commando setup now much will be filled in. Right now, it looks like a bit heavy guy with tiny legs... very top heavy, where the CJ setup is more overall balanced.
I don't know, I just confused myself even more by doing this.
Overhang picture and you can see the gap along the fender.:
Side Profile:
Also, the "wings" would have to be notched or the flat fender recessed as it comes up higher than the stock setup and it won't allow the wing to pivot down onto the fender part so they are parallel to each other.
Let me know what you think.
Have you seen this thread?
http://www.wranglerforum.com/f282/jeepster-commando-grille-on-a-tj-368530.html
Jeff (a member here) has designed a similar project. He has also designed a flat fender kit.
He does a lot of design work and drawings before starting creating his parts. He has created many drawings for people on their ideas for changes to his products.
I guess what I'm suggesting is reach out to him for photos he may already have to compare what you are considering, or he may be able to produce something for you to compare.
:twocents:
