TJScrambler - Getting Started
CB this might come in handy for you.
I used this 3M Body Panel Adhesive on my '83 in a couple of places and found it to be pretty amazing stuff. There is a fast curing one but this one bonds in four hours and is completely cured in 24 hours. If you prep the pieces correctly, clamp it together for 24 hours and you won't be able to drive a chisel between the two pieces. It may be as good as welding but will certainly work where you can't weld.
That turn signal lense is very orange. Is that the Louisiana high heat special ? :smokin:
I've used that on door skins and extend cab corners and it's great stuff (you can't separate the pieces). Only problem is it's not for structural components. After I did the truck work they came out with a structural epoxy that has the extra strength. http://3mcollision.com/3m-impact-resistant-structural-adhesive-07333.html. Most auto manufactures use epoxy to install certain panels on cars for many years.
So, after thinking about it last night, I am just going to replace both corners... the one side is OK, but it has a bunch of filler on it... figure do it right now when it is apart... ordered up some rear corners and some adhesive, so I will give that a go in the harder spots.
When I was doing the UK rear corner replacement that would have come in handy... I could weld in 80% of the areas, but the other 20% would have been nice to have that.
I have some other things going on, but hope to remove the rear corners this weekend and get it all prepped out for the new stuff, then I can replace those next week and get it all burned/glued in and then be able to mount it back on the rotisserie the "correct" way for more balance and then attack the rear floor.
I also used the body panel adhesive as exterior seam sealer. I would let it cure at least 24 hours before painting though.
New parts
Doesn't look like I but very long day
Can't find tailgate hinges either
Not sure where it came from... I just picked it out of the pile that I have... oddly enough, no tailgate hinges on any of them. Have to look harder today.
Found hinges. Had to loosen them up. Measured 15x or so times and then socked them down with machine screws. Gonna glue and weld. So as she sits now all glued up. Welding on Tuesday. Give it 2 days to bond<br />
<br />
<br />
<br />
cb<br />
Coming along nicely. Be ready for paint in no time:rolleyes: Seriously it won't be long.
