Low budget engine/drivetrain swap
Strike my last sentence. I should just find the stock bellhousing that comes behind a 4.0. The CJ bellhousing can be drilled to fit the different transmissions.
What years did MOPAR use the 46RH? Did it come behind both the 6 and the V8? And can an adapter be used to mate it to the Dana 300?
The 46RH is not electronically controlled, FWIW.
Yes, you can totally do the CPS at the balancer; that's how the MOPAR MPFI kit for the 258 is set up.
No, the CJ-transmission bellhousing won't bolt up to the AX15. If you look at the front of the AX transmissions, you'll see they're shaped completely differently.
I've never heard that the fuel rails are different, but at the same time, I couldn't confirm that for you either way.
Well, maybe; the stock 4.0L bellhousing uses the hydraulic clutch (and I think there are two different versions with an internal slave and an external slave; somebody might have already mentioned them in this thread IIRC). If you want to use the CJ mechanical clutch (or even the CJ hydraulic clutch), then you'll need to use a bellhousing designed to accommodate the CJ throwout lever.
I've got a buddy who was swapping the AX15 in his '95 YJ with the T-176 in his brother's CJ-7; they were both built, but the 7 saw more street-time and wanted the 5-speed, while the YJ brother liked the idea of the stronger cast-iron transmission. To do it as cleanly as possible, they were going to swap clutch linkages and swing-pedal assemblies too. But the YJ was to keep the 4.0L, and needed the CJ bellhousing for the clutch linkage. Rather than machining the CJ bellhousing, he just picked up one from Advanced Adapters specifically designed to mate a 4.0L to a CJ.
So, yes, the stock CJ bellhousing can be drilled to work with a couple different transmissions.
But you don't necessarily want the stock 4.0L bellhousing, unless you want to use a YJ hydraulic clutch system. And then you need to figure out which style of slave to use.
The 46RH never came behind the 4.0L; it's strictly a MOPAR bolt-pattern. So if you go 46RH, you're committing to a 5.2L/5.9L engine. At least in ZJs, it was used from '93-'95.
The 300 has been mated to the 46RH before. It'll require a clocking ring and the correct input shaft from Advanced Adapters.
Thanks for all the detailed info. There is a better chance that I'll make a choice that works now that I know some of the differences between the years and models. Once again, you guys are awesome.
There is no real difference in the fuel rails for Auto/Manual, but the Renix and MOPAR I think are different. Same injectors though.
The Iron Duke 4cyl is the same bolt pattern as the SBC so if you have one of those then conversion is easy with a 10.5 clutch. There is info on this site about that.
The Y-176 is a ford pattern transmission and the T-18 shares that bolt pattern to the bell-housing.
Watch transmissions on the YJ's the 4 cyl AX-15's are 21 spine and the 6cyl ones are 23 splines as are the Dana 300's, They just have a little more stickout which is why they require the spacer.
Lets See are there any more questions at the moment?
Carl
I have a hard time parting out a CJ. My handle should probably be Jeep Rescue. Even when I buy one for parts, I somehow end up putting it back together. So far I've been staying with CJ or YJ parts. I noticed a 1976 Amc 360 in the ads for $200 that runs good. Thought about putting it in my 82 CJ7 parts car that has a 6 with a hole in the side and the automatic. Would that bolt right up? So far I've only had sixes and fours. I know the sixes are tough and I get up to 18 mpg with them. Will that 360 get 10 mpg and better suited for a boat anchor, or are they good engines? I was thinking about the desirability of all these engine/transmission swaps that we've been talking about. I enjoy gathering the parts and putting the CJs back together. But most of them I'll have to pass on to a new owner sometime in the future after I play with it for awhile. Which of these relatively easy ways to put them back together will be most desirable by the majority of people looking to buy a CJ8 or CJ7? And which would be less popular? Although some will have a small lift, they will be for the road rather than climbing boulders. So what do you guys think? What engine/transmission combo would you prefer to find in a CJ if you were looking, or which combination do you think would sell the best?
The 360 for some reason is really bad on MPG. Really easy swap. Find motor mounts out of a slightly older CJ with the 304. They will bolt right in and work for all 304/360/401s Same block. Also all have the same AMC bell-housing pattern. The MC2100 carb works well on that engine too. I think you have to go with an AMC specific HEi if you want to go that route not a slightly modified Chevy 6cyl like the 258's.
The Howell TBI is a pretty good swap and helps some with the MPG. Still not a great improvement.
For resale, folks like the V-8. Well folks new to the sport and driving on the road. So it might be a way to get in and out quick if everything else works. Like transmission, Transfer Case and differentials. Pluss you can put on a quick dual exhaust and make some noise. Good for resale.
So all in all not a bad deal if you do not have to pass an emissions check. Depends on the local area I guess.
Oh, and MORE makes a nice set of bomb Proof motor mounts that bolt up too.
Carl
Another tidbit of information about the AX15. The ones from the Cherokee have a different shifter compared to the Wranglers. The shifter is shorter for the Cherokee and you will need to buy a longer one from a Wrangler with the taller shift tower. Also the clocking is different for the transfer case. The Cherokee point down further. I think it was 10 degrees for the wrangler and 23 for the Cherokee so a clocking ring will be mandatory.
