TJScrambler - Getting Started
Glad you listened. How did you luck out and not have to replace the floor under the roll bar feet (or is that next on theach list.
I have gone through all the repairs you are doing. I now feel I would have been better off if I would have bought a new tub.
Do you ever think you should have bought a new tub?
You asked the same thing in post #79... and it still hasn't changed, but I will re-iterate for anyone else going down a similar journey.
Those that have gone this far will know how tired, disappointed, exhausted, and apprehensive you get when you have a giant hole in the body and you keep finding more to repair.
All the classicent panels cost so far cost $2200.00 and I have $500 into the body give or take.
I probably now won't use 1, or possibly 3 of the panels I got from classic ent, so that brings down the cost about $250.
The cheapest cost delivered (unless I can find a tub someone isn't going to use) is $5000.00.
Requirements are:
1) I want steel, no aluminum/kevlar/fiberglass
2) I want my bulkhead to fit
3) I want my 1/2 hard top to fit
4) I want my existing cage to fit.
5) I want all lips/edges to have a factory look/feel
6) I want my original rollbar and wooden side boards to fit.
The only way I could justify $5000.00 for a new tub is if it were perfect.
I have read too many posts (with pictures) that show that anything from a certain company, who is actually trying to improve the process, still can't get the exact dimensions correct for side panels.
Even the rear panels I bought (non classic ent as they don't make them) aren't perfect.
They are only perfect twice... when they are brand new, and when the NOS parts are still available.
I don't have those options.
I also don't have the time to drive cross country to pick up a decent (or even excellent) tub (if I can find even find one), and still pay $2000 (or more), plus all the fees included (diesel/trailer/tolls/food/hotel/etc).
So, the tub I had was original.
It was used in a restoration in the 90's.
It was done so-so, but saved a lot of the important parts.
The bed and rear were trashed, as are the footwells.
As I tear apart this onion, I am shocked that it held together as long as it did.
I will fix it.
It will be nice when it is done.
It won't be perfect, it is a restoration, using aftermarket panels.
It will take a long time.
It won't be perfect.
I will find more areas of concern along the way.
I will fix what I can to the best of my ability.
This is being built for my daughter, I want to do it for her and do the best I can.
I want to show her how it is done, the "correct" way, according to me and my beliefs.
I want to show her that if you put your mind/body to it, you can do it, it will take hard work, dedication and perseverance.
It will not be perfect.
It will be hers forever and hopefully she will learn a life lesson about wanting something and doing what is necessary to achieve it.
So, $5000.00 and not having some of the things I want, or $2500 (plus a ton of time) and doing it the way I see it to be right.
At this point, I will save the money and go this route.
I hope I explained everything in my head, if not, feel free to ask any questions.
The sermon is over, everyone return to their daily lives ;)
So, in the middle of the night (after a few margaritas out at dinner), I wake up in a panic that the rolled bead break is not in the right place.
I know, seems strange to recall a weird fact like that, but I guess when the brain is at rest, it will do strange things.
Anyway, I had thought classic had rotated the panel 180 when the attached it all... turns out, it was not, and they are correct in ewhat they did, I just had put the panel in/out so many times, I guess I had it turned around in my head.
The replacement is spot on... really nicely done. The only major question I have is why is there a break in the panel on the rear driver side on the rolled bead?
You can see the old vs. the new here.
The only minor thing I noticed was the rear and how it mounts.
They cut out tabs that go around the tailgate latch, but they didn't do it in the right area.
Basically factory and their way deviated, so they did it over the rear panel and in the factory it was under.
I still have the piece, so I can take a picture of it and show later today, but basically, this way is fine, I just had to do some modifications to accomodate the new way.
Now aren't you glad you did all that temporary bracing?
I hate to say it, but in retrospect, I think I would have maybe done one on the underside as well to keep the side panels perfectly in line... the top stuff and inside tub stuff is great, and it stiffens it all up, but when you roll this on its side, it tends to deflect/flex a tiny bit now that the wheel wells and roll bar mounting plates are not attached to the new floor.
It wasn't an issue when it was all rusted/attached together, but now that it is free, I saw a little flex.
Once it was cleko'ed in place and cinched down with some sheet metal screws, things went back into alignment right quick, but you learn a little bit each time you do one of these things.
Hope you can get some better sleep tonight, I have never figured it out either. CJ5s and 7s have an area like that too but more in the middle. Here is what you are aiming for. About the only difference I can see is no drain holes or rear seat mounting points
Edit - white dots are factory hole plugs for rear seat mounting points, facing forward in exact same position as CJ5/7. However this one a PO put his/her own rearward facing rear seat, and the areas of less dull paint are where it sat on rubber mounting pads...
Keep up the great work. :thumbsup:
Requirements are:
I will fix it.
Agreed !!!
Sent from my iPad
So this is the difference it attaching. One was inside this one can't with how the bottom part was made
CB, I agree with you. I finished my '81 restoration 4 years ago and I still catch myself standing in front of it at night just staring at it with the feeling of accomplishment. Yes every dollar saved or spent is worth it. Every hour spent, every busted knuckle and all the blood on the floor is well worth it. You answered my question 100% correct. Keep up the good work. It is worth it.
Ugliest onion you ever saw to peel back. It wasn't fun. Every tool in the arsenal came out today. Good thing wife had the kids and play date going on inside. Had a few choice words
After drilling and drilling
Horribly thick bondo
All is removed
Trial fitting
Removed 10x and fit more
Finally view
I am done for the day but a good day. These will take a while
What you and Graveltravels is doing is just amazing. I could do sections but to basically rebuild sides and floor (what my spare tub would need) all I can do is take my hat off to you. I can't imagine keeping everything lined up (once somethings off, the rest snowball from there). Love watching someone do a rebuild like that. So much to learn from. Keep up the good work.:bow::drool:
Thanks a ton. It is coming along great. Today was just a slow painful reminder that jeep bodies are superior to us mere mortals
Cb will you slow down please!, you will have finished this one too before i have finished mine....
You have done right though, rebuild what you have if you can, if CE would of sent me the parts for mine i would of done the same (possibly over a period of 5 years though not a week....)
