My De-Rustification Project
Awesome!! Looks good. Saw it on FB first, so had to stop in here and see all the pics!
Thanks. Only forgot to cut one ground wire. It was the one for the fuel sending unit. Also found out why my gas gauge was dead. The sending unit wore was broken at the tank.
Great work. Having a folk lift is easy but nowhere near as much fun as a bunch of mates helping out.
About the wife thing, they all know you have way more fun with your jeeps than you do with them and man it burns them up. That's why (mostly) they get angry when you're spending ("wasting") free time wrenching or driving around.
I know I'm the lucky one :) My wife thinks the Scramber IS hers so she only complains when it's not running and she can't use it :thumbsup:
Great work! Wish I could have been there to see it. Let me know if you need me to come down again as well.
Thanks Chris. I will let you know. You are welcome anytime. I will be working on it for at least the next few weeks to get it going again.
I was looking at the steering shaft. Not sure how I am going to get that thing to go in without taking the steering box off again. Your remember that. Don't want to put that on again.
Oh yes, I remember. Did you get a new shaft? The Borgeson is collapsible. You shouldn't have to take steering box off.
You've taken the easy way. I've always did the tubs by myself. Looks like more fun. I see what you mean on the frame. Almost more patches than original metal. Glad to see it's coming together.
Not sure I would even know how to do the tub move by myself. Without a crane or forklift or something
Before the tow motor I"d jack the tub off the frame enough to put 2 x 4's under the tub. Then jack the 2x4's up enough to roll the chassis out from under the tub. Your way is more fun.
So while the Jeep was sitting out in the driveway, the MC and booster got really rusty. I am either going to have to clean them up really well (and paint them) or but the budget a little and pick up a dual diaphragm upgrade package. Kicking this around in my mind. Ugh.
Oh and I already ran into a situation of "hmmm, what hooks up to what?". It looks like I have an extra hose coming off of my charcoal canister that I don't know what to do with. I will post up a pic later and see if the gurus here can point me in the right direction.
There is sooooo much to do right now, but at least I can get started on it. Other than waiting on the fuel filler and vent hoses that I ordered for the 20 gallon tank. We will see if they will fit or if I need to extend them somehow. I am guessing the latter based on my luck.
So tonight I had to do something. So I attached the half top and put the gearshift back in and covered it al up. Also attached the vacuum hose from the manifold to the brake booster. Still a long way to go. But it is down hill from here. Right? Right? Convince me. Please. At least it is looking like a Jeep Scrambler again.
Dain when you figure out how to keep a MC from rusting please let us all know. Until then I'm going to try this one.
Wow. That is super shiny. And that motor is just beautiful. So jealous.
My old mc was fine for the whole time I owned the Jeep up until last year or so (5+yrs). Then I had to replace it. And this one looks like crap within a year. Disappointed.
So, this morning, the dogs got me up an hour early. After tending to their needs, I tried to go back to bed. Too late. My mind had gone to the Scrambler. I started to list in my mind all of the "little" things that I need to do to get it done. sigh. I had to get my phone out and start writing it all down on a "notepad". Then as I was getting ready for work, I thought of more. And I am sure that there is even more yet. But the list is long. Granted some are things like putting in the oil and the coolant, etc. That way once I do them I can cross them off the list. And I REALLY don't want to forget to put the fluids in.
In any case, these are all things that I can do without having to enlist 6 or so friends and beg for manual labor. Those two steps are past me now. Not that I mind the help, it is the asking.
Anyway, the weather is looking clear this weekend, so I should be able to get a bit more done. I can't wait to get the front clip on, but there are things on the list that would be easier to do before the fenders are attached, so I will be patient (dang it, I just thought of another thing to put on the list).
List (in no particular order other than how they came to my brain)
install clutch linkage
cut the remaining body bushings and install
install speedo cable
create access panel to fuel sending unit in bed
run the wiring harness for the rear lights and fuel tank
Ground the rear lights to frame
paint the stupid body mount plates under doors
install seats (after cleaning inside floor)
create grill spacer to account for body lift
drill holes in fender mount metal bars
hook up the evap canister correctly
new hose for brake booster
R&R front and rear bumpers
figure new way to install rear bumper
run wiring to tranny and t-case (reverse light switch and 4wd sensor)
add oil and new filter
add brake fluid
add coolant
add power steering fluid
bleed the brakes
add new fuel filler and vent hoses
reconnect the engine wiring
install roll bar
weld in frame tie-ins
alignment
new rear axle pinion seal
new u-joint for front drive shaft
change front diff fluid
battery hold down
axle shaft swap
I hate list and refuse to make one. It would just depress me.
If I had made a full list when I started this, ........ well, I never would have started.
