Exhaust routing with a 20 Gallon n tank?
gr8dain
Old and Slow
Ashburn
VA
Not sure where to post this but here goes.
So in my frame swap project I was lucky enough to get a 20 gallon gas tank. Can't wait to use it. But when I was moving the exhaust to the new chassis, I noticed that where the pipe ran before was between the leaf spring and the tank, but there is no room now with the bigger tank.
So it hangs super low now going under it. I need to rectify the situation. Does anyone with a 20 gallon tank have a pic of how their exhaust is routed? Will I have a problem if I have it turn outboard after the axle and go under the frame and above the leaf spring to exit behind the tire?
I don't have a photo at the moment, but mine is routed just like you said, behind the tire, between the frame and the leaf spring. I'll snap a photo and post it later this morning, if nobody beats me to it! ;)
Great. Thanks. I need to get mine done that way before it gets crushed.
This is on my Tan Scrambler with a V8 and single 3" pipe, clears the 20 gallon tank/spring/shackle/tire just fine :thumbsup:
Found a better picture of my red Scrambler, shows the routing better:
I have smushed the very end of the pipe a few times, while doing "interesting stuff", but it is easy enough to open it back up with a crescent wrench :thumbsup:
Thanks a lot. This helps. Now to see if it is something I can do or if I will be taking it to a "professional"
Here's a few shots of mine. I can pull the wheel off tonight if you need a closer look, but I think these show it pretty well. Eventually I'll put in longer YJ springs and shackles, which will open up that space a bit more.
Dain.. I have a full exhaust from the 258 I removed and sold, exhaust manifold to tailpipe (minus the cat conv), that you can have if you want to pick it up. Previous owner had revently replaced it so it is still all shiny clean galvanized looking after the manifold. I was thinking about cutting it up to scrap it. Bolt on frame brackets included.
I will even meet you part way if we can find a time that works.
Thank you and yes. How close are you to hampton roads? That is about 4 hours from me. I may be driving to SC as well, but that would be early May.
Let me know and let's work this out.
My exhaust with a 20 gal tank. Not much for off road though.
zr.. Did you go inside the shackles on the back? With my 20 gal tank, they practically touch the sides of the tank skid. Mine looks like yours, but turns out the sides at a 45 like stock at the back.
Inside the shackles then along the bottom of the frame rail to the back. A lot more clearance than there appears in the picture.
When I did this a few years ago I was able to purchase all the parts at the local Autozone. I did weld in the Cat though.
Dain, my exhaust system is 100% stock from the local bumper to bumper or auto parts store
