- Gonzales
- La
I checked mine and I had between 4 and 5 lbs at the carb but with the by pass fuel filter the Weber ran fine. One thing I did find out is that the fuel filter needs to be laying flat and the 1/4" by pass hose needs to be turn so that it is on the top and the fuel line to the carb is at the bottom. This little things make a difference.
Another potential problem is if your fuel tank vent is plugged or if the charcoal filter has been removed and the fuel tank no longer has a way to vent it could lead to added pressure in the carb because now the by pass line on the fuel filter is not allowing the extra fuel to return to the tank.
