Oversteering woes
If you can turn a 1/4 turn with the motor not running then you need to inspect for where the slop is. Have you updated the steering shaft yet?
Sent from my SM-G920V
Yes, borgeson heavy duty shaft. New steering shaft bushing done same time. Shaft and seal were the last items done, because they were the only left to do.
I'm gonna take off the belt tomorrow and run it as manual steering.
I can turn the steering wheel and while holding the steering shaft too, I have a little less than a 1/4 turn of play before the shaft moves. Does this mean the problem may be in my column? What are the components associated here?
Like I said in previous post, I had replaced the shaft and the bushing to column last. Is there more toward the steering wheel?
Just another thought...
Has anyone checked the splines on the steering shaft and steering wheel?
With 33" tires and all the other upgrades that tightened the steering up this could be a weak link, just loose or splines damaged.
Should be easy to check.
If you have a tilt steering column there could be a worn parts in the tilt components.
It is a tilt column. What do I look for in the column?
The steering column shaft has a swivel joint that may be worn. Try watching the lower part of the steering column shaft while someone else turns the wheel to see if the play is in that swivel joint.
Kim, is that joint you're talking about about a foot from the firewall in the engine compartment where the proximal end of the steering shaft connects?
I can turn the steering wheel almost a quarter turn without it even moving the steering shaft.
Ok, then it's definitely in the column. I can turn the steering wheel 1/4 turn almost without it even engaging the steering shaft. I just spoke with a local jeep shop and they're telling me it should be a $500 job if the column isn't completely worn out.
On ebay rebuilt tilt columns go for almost $900. Another is $450 or BIN for $600. So unless you disassemble it yourself and locate the parts to do it yourself, that $500 is probably the way to go. After replacing so many parts, I hope getting your steering tight finally takes care of the problem.
I can't believe that the other 5 shops didn't catch that. I'd avoid those places like the plague.
Well, you guys should know too, always assumed that it's a bad box or tie rods, etc!
Well to be fair, your symptoms have changed since your first post... you started out saying, " if I move the steering wheel just a millimeter left/right I get action," and you ended up saying, " I can turn the steering wheel 1/4 turn almost without it even engaging the steering shaft."
I agree with mysunnshine, one of those shops should have tracked down the loose steering to begin with.
Wow.....I feel violated for even helping at this point. All of the info given was assuming that the 5 shops that installed the parts made accurate diagnostics along with your added info too. In all of the years that I have been turning wrenches for a living, I have never come across a tilt column joint wear failure. When the steering shaft or the steering box was installed, that steering column issue should have been caught at that point with no exceptions.
That's a good point, but that's how it feels while I'm driving as to why I label d it "oversteering". I agree with you too
Oh, in no way did I mean to infer that "you guys" should have diagnosed it, what I meant was that you all know too well how shops will just dismiss you and say that it's a worn steering box/bad steering box/factory bad box and start replacing parts, then work their way towards the shaft.
Literally I've had everything replaced at least once(3 gear boxes), and it drives the exact same since the day I bought it. God help me if it isn't the steering column.
The possible causes earlier listed it's usually one or more of them. Steering columns do cause problems but not nearly as much as front steering parts. You usually just work from what usually is the most common problem (rule them out) and then search the ones that aren't the usual problems. If we were there and turned the steering wheel we would have felt the slop (compared to out jeeps). If it is the column, 39 posts is not bad in finding the problem. Some can go into the hundreds of posts. Hope that is your problem, better to know than to go crazy trying to find it.:cheers:
