Windsheild wiper upgrade for Stump Jumper
zr10054
Car and Gun Junkie
Gonzales
La
As many of you know my Stump Jumper Scrambler started out as a burn casualty. Well I far enough along that I need to order all the wiper components. I've never been to happy with the wipers on my "81 Scrambler and would like something better on this one. Does anyone know of a direct replacement upgrade that will fit these trucks.
Per the suggestion of Dain, I used the YJ linkage and it was a big improvement. Just have to make the holes a little bigger and it's a nice upgrade.
https://www.cj-8.com/content.php?66-Installation-of-YJ-Wipers-and-Linkage-on-CJ-Windshield
As Chris said, I pulled the YJ linkage from a parts rig someone had and have not looked back. Same CJ motor, bit all of the rest is YJ. I was not going for originality, so I did not mind the black wiper arms and bigger holes being drilled. It is a good option for you if you don't mind YJ parts on you CJ.
Why would I mind YJ parts on my CJ when most of the drivetrain is GM. I'm not sure how much CJ is really left.
Hmm...Dennis, I'll let you go first on this. But Copper is going to need a new frame at some point- and this looks like a good option.
I like that idea. My problem is I bought a new CJ replacement frame and seal and it's been painted. I actually just brought it to the glass shop today to have the windshield installed. I am looking at installing the YJ wiper assembly though.
So Randy, looks like you'll be first on this one.
Don't forget that the YJ's glass is glued in and not an "H" seal like the CJ. Better seal, so less leaks.
We will apply a small amount of sealant on the new seal anyway. But while we are talking about leaks, take a look at my picture in particular where the hood hinges bolt onto the cowl. If water leaks through these four holes guess where it ends up. I bet most people don't even give this a second thought and just wonder where all that water comes from, maybe even thinking it's coming from the windshield. I'm going to make some neoprene rubber gaskets to install under mine. Also, how old is that rubber washer around most owners windshield washer spray nozzle. You think that might leak too?
That thread is pretty good for the YJ frame swap.
If someone decides to try it and needs pictures that are not shown there let me know. This is done on mine and works great. Definitely a big improvement in wiper linkage and arms. I also have the YJ motor to CJ delay box/switch wire color match if anyone needs that (I would post here but I don't have handy right now).
I will put up pics as I go further... I am putting baffles in the frame so more air flows onto windshield in defrost. And I picked up a set of YJ roll bar to windshield frame side bars. I am going to modify them to scrambler dimension for better entry/exit grab handles and to reduce stress on cowl/hinge mount points during top off driving at speed.
I did a YJ swap too. works great!
Why is it that even the simple things I do turn into a big ordeals? Duh .
Besides, when it's raining I usually take the Hummer H1 anyway so that the crazy drivers can just bounce off without hurting me. But most of the time they just stay clear. It sure serves a purpose.
Because no matter what vehicle it is, you want it to work right. Period. I out up with my crappy wipers way too long. So much better.
The straw that broke the camel's back was when we had a horrible snow and it was coming down faster than the wipers could handle and the weight of the snow caused my linkage to snap and one wiper bailed on me and parts hit me in the chest (no blood, I promise) and the wiper was laying in 2 feet of snow on my hood. Fun trip home with my arm out the window using my snow scraper so I could see through the windshield.
Been there, done that. Vacuum wipers in an early Bronco. Can you say SUCK?
I had a old truck once with vacuum wipers, I think it might have been a 65 Scout, yes I know how to yell "SUCK".
