Scrambler UpGrades - Pappywaho
We had it running!!!!!!!!!
Should finish the wiring within a couple days.
The Scott Mine LOOK!
Kinda been slacking on getting the pic's posted.
New winch mount.
Pap decide to move the winch over from his black Scrambler. The old Pierce was just to slow.
We are heading to Clayton this coming Thursday.
It should get broke in or broke!
Been a long while since we've posted about this build/rig.
Well, it's going to get a new power plant soon. 2001 Chevy 5.3l LS (34k miles)
Stay tuned in !
Pappy reworked the OEM harness
5.3 mated to the TH350
Working on the motor mounts
Had to relocate trans mount which means changes to drive shaft lengths.
Working on fuel delivery. Intank fuel pump on CJ sending unit
I wanted to do that same thing with my sending unit but the tubes on my version are too short to fit the fittings before hitting the 90 degree bend going down into the tank. Do you happen to know what brand sending unit that is?
Thanks
You're not concerned about the rubber grommet getting hard from the fuel and cracking/leaking?
Sent from my SM-G920V
You might want to look into that new Holley fuel mat for the pickup. They come in lots of sizes and will allow you to pick up from almost anywhere in the tank. From what I can tell they seem to be a nice upgrade.
Also have you looked into using the Hooker conversion headers for the swap?
Also, I need to hit you up for help in parts for my Jeep. Got to finish the sons build up, then doing the same 5.3l upgrade on mine, but I was planning on the 4l60e.
Carl
I don't know how I missed this build. I love these projects. If anyone is interested I have a Advanced Adapters kit for installing a D300 to a 4L60E that I decided not to use. I decided to go with a 241C TC.
Starting exhaust
PVC mock up pipe/fittings
purchased a couple 2.5" pre-bent pieces of exhaust pipe
also a 3" I.D. ball & socket joint
going to modify to accept the 2 2.5" coming off the manifolds.
