It's about time to start building the steering and the brake/throttle pedals now. I think I'm going to make both the floorboard and toe board removable for service.
The floor now is almost done. I just need to build a little hump to cover the top of the transfer case. The steering shaft is mocked up but I think a double joint up top will help the angle a bit.
The filter will be kept in the engine compartment because of the noise. Listening to intake noise from a single cylinder motor will drive you crazy... just ask anyone that has been on an old school Ski-doo with the air intake right in front of you spitting fuel back at you from the reversion.
Wish i had the time to build something like this, but are you sure this is for your boys or will they be able to use it when you have finished "test driving" it??
My boys run their rc crawlers quite a bit and are starting to figure it out with picking good lines. Hopefully they will break this less than the rc's. I'll run this just enough to shake it down for problems and then it's all theirs. I'm ready to get it done so I can work on my own Jeep. This little project has delayed the installation of my aluminum dash and linking the suspension. Damn kids....lol
