sxer
- Long Prairie
- Mn
The "right" gearing depends on your type of driving. How high do you want to rev it in high gear for extended periods if you use it on the highway? Isn't the T-5 overdrive in high gear? If it is, it would allow you to run steeper gears and not over rev the engine.
I have an '81 with stock 258 with the HEI upgrade and stock BBD carb. It starts and runs perfectly. I have the stock 273 gears. I do some fairly long trips so they work for me. The engine runs about 2200 RPM at about 68 MPH. I can cruise all day long at 65-70 and get an honest 17 MPG. I would like steeper gears but don't feel comfortable revving it much higher on the highway. I use low range when I am off road and get by. My opinion is do the distributor upgrade and get a carb if your stock one doesn't work. Get rid of the smog stuff if you can, make sure it is tuned properly and enjoy it. If you want something to set you back in the seat and pull a load, go with a V-8.
With that much weight, using the V8, I did not use overdrive. Big no-no to pulling heavy loads with a 4L60 in over drive
