Holley carb to stock CJ charcoal canister question
cw05
Wilmington
NC
Does anyone have any pictures of where they routed their Holley carb/Edelbrock intake (with carb and intake pics) to the stock CJ charcoal canister? I know this is a frequently discussed problem but all the searches show I6 motors with either Weber or Motorcraft carbs. I am running a AMC V8 with Edelbrock performer intake and Holley 670 offroad Avenger carb. Currently I only have the fuel tank vent hooked up.WeberVacuumHookup2.jpg
The Truck avenger is a little different, but same ideas.
Rear port is for power brakes. It is full manifold vacuum, so it will not hook to your canister in any way.
The large front-left side port near base of carb is for PCV. You will T in hose "E" from your canister (shown in your picture) to your PCV hose and hook them here.
The small port on the mid-upper passenger side of the front carb body is the timed spark port. This is ported vacuum and it is where you will hook hose "C" from your picture. If you are using a vacuum advance distributor, you will T this line with the hose to the distributor and hook here.
Plug the Bowl vent hose "F" in your picture as there is no provision for it on the Holley and it will not be hooked up.
The large front-left side port ....
Sorry - I had a typo there. The PCV port is on front lower right side.
And then cap all ports not used on carb or you will have a hard time tuning it right.
Thanks for your detailed post....the carb is tuned great but the fuel smell is killing me. I wonder if just capping the open ports on the canister would help with the fuel smell...I hate to mess with it since it is running so well. I'm not running vacuum advance. I could not get the Comp 292H cam to run right with it hooked up and I drive it so little I'm willing to compromise on the lost fuel mileage.
Capping them may help the smell for a while, but the can will eventually get saturated and likely leak. The fuel tank has to vent somewhere as the outside temp changes and fuel is used while driving. You can:'
- Seal up canister and use a vented gas cap. This will make the rig smell like a 50s/60s car; tinge of gas and oil all the time.
- Hook up canister so it vents like original. If you do this and it smells, it means you have a leak somewhere. And, you may get random hugs from the bunnies you save.
You should also check to see if your vacuum purge valve works too. That is what hoses E and C are hooked to. If you can blow (I think) or suck (for sure this is a test) air through hose E while hose C is not hooked to vacuum, it means the diaphragm in the valve is bad and it is venting all the time.
You can not repair the stock valve, but you can seal up the C port and put a new inline valve in hose E to fix it.
