- Northville
- MI
Hey,
Upgrading my AMC 20 with 1 piece Moser axle shafts and Detroit Locker. I have been doing some research and had a few questions. From what I have read, when installing 1 piece axle shafts, you need to remove the thrust block from the differential in order to prevent excessive preload on the outer bearings. I have found instructions on how to do this for the standard diff, but nothing for the Detroit Locker. Anyone removed this thrust block from the locker? Or, maybe it is possible that the Moser axle shafts were designed shorter so there is no interference?
Second question, when looking in the 1982 TSM, on page 2F-29, the manual says to torque the ring gear bolts to 55 ft-lbs. But, on page 2F-40, the specs say 105 ft-lbs for the AMC 20. Anyone know what the correct torque is?
When you slide in the axle second shaft, you will find out. I have only ran across this issue with the factory LSD, and had to remove the thrust block out of everyone to get the Moser axles to fit correctly.
