- ORLANDO
- FL
Can someone take some pictures of the holes in the hard top for the shoulder seat belts and give me some dimensions for size and location? I have the grommets that are utilized, and I thought the way set was created was a 1 and 1/4 inch hole with the grommet fitting in the hole and the seat belt attached to the roll bar. But then I saw a post which stated the hole in the top only had to be large enough to accommodate the hole for the bolt for the seat belt, leaving me to the think the the grommet was actually on the outside of the top and snug on the roll bar.
If it helps there is about a half inch of space between the roll bar and the cab.
thanks,
frank
thanks,
frank
