Metal strip on hard top
finorman
Gold Member
ORLANDO
FL
Couple of the rivets on the strip for my metal top are out... I bought the McMaster brackets but I thought the brackets attached to the metal strip. I was thinking of cutting out the rivets, cleaning the rust off the metal and replacing it with rivets.
This is the first time I have used a rivet gun. Do I just cut the heads off the old rivets and remove the metal?
Any suggestions on which rivets I should use?
The brackets didn't come with screws/bolts. Any suggestions on which screws I should use I should use?
You are on the right track. I replied to your other post. But I drilled out the old rivets, reattached the strip to the top with new rivets and then attached the latches to the strip and top using rivets.
Here are a couple of pics
And by coming to the garage to take these pics, I noticed that the strip popped off on the far passenger side. Gonna have to fix that before it goes back on for the winter
are all those rivets the same? should I use the biggest rivet in the box?
Use the largest diameter rivet that will fit in the hole. The length should be about 1.5x the depth you expect that hole to be.
When I installed the latches on my top I ditched the metal strip and used rivet nuts in the fiberglass to secure the latches.
https://www.mcmaster.com/#97217A359
I think these give a stronger attachment because they spread the load better and sandwich the fiberglass instead of putting pressure on the sides of the hole like most rivets do.
Also allows to to remove the latches easily if needed.
I had previously posted pictures, but not sure where they went as I can’t find the tread here or at jeep forum.06E70B0D-B248-4670-8D1F-C802A3485A62.jpeg19A392DB-3BC2-4F9D-8D47-455F516FCE3F.jpeg
Rivnuts would be great. I just happened too have a rivet gun and a ton of rivets on the shelf. And they work fine. So far. Just need to make sure they spead enough on the backside so they don’t pull through.
