'83 4.2 258 vapor locking
Valve cover is an Omix-ADA. I think I got mine from Summit. A bit of a pain to install, but stopped the leak and looks good.
Vapor can easily happen when running 4-7 psi and I have used the clothes pin trick when I used to wheel in the desert back in the 90's. You can also wrap a water soaked rag around the fuel line if you run into the issue again and it should get you up and running pretty quickly since it will cool the fuel down and prevent the boiling from happening.
Similar to this, I've crushed a decent amount of aluminum foil around a hard line over the valve cover (not too tightly, just enough to basically hold it in place) on a Jeep that was holding up our trail group with repeated vapor locking (prior to the lunch break when I tried this) and it didn't have any issues the rest of the day even though it got hotter out. Thought it might act as a kind of heat shield and it seemed to do pretty well :shrug:
Well, attached photo is where are in the "Vapor Lock" saga is as of today!
Discovered that the fuel tank return line was not connected so ...
I have now eliminated the duel outlet filter and replaced with a clear view filter until I can determine fuel flow to the carb. Relocated the filter to a closer to stock position (rember it was on the opposite side wheel well with TWO lines returning) and changed the hard fuel line to a braded injector type fuel line.
Fired up first time (after filling the carb bowl)
PS. Also reset timing to 5 degree BTDC. (it was off 3 retarded) Test drive proved to give an incredible power increase and fires up great. Will find out in the morning if I still have to pump the peddle and drain the battery for the first fire.
Please keep in mind that without the return flow the fuel will stay near the hot engine longer and possibly heat up even more. The return flow regulates pressure but also keeps fresh cool fuel in the line.
Thanks for the heads up! I’ll be watching for that specifically and may put it back in if necessary (even though it only go to the canister and never makes it to the tank- apparently disconnected by a previous owner)
PS. Also discovered the location of the Computer Emission Control module (also was unplugged and abandoned years ago as well)
Thanks again.
Chas
