sevensandeights
sevensandeights
- Mckean
- PA
I should know this but I can't recall what this is for?
Thanks! Next question is does the plug for the resistor have to be connected for the blower motor to work? Mine was disconnected and the blower motor didn't work. I connected it but the blower still didn't work. Tested the resister plug with a test light and have power at one of the three prongs with blower switch on. I have yet to test the blower motor by itself.
You are probably correct about needing the resistor to be plugged in. I can't remember if the high speed control wire was direct to the motor supply or if the switch sends power to both the low and medium speed wires at once to make the resistor send full power to the motor (for high speed).I am pretty sure (call it 99%) the fan --won't-- work without the plug.
I believe there is only one wire to the blower motor (this is the power supply that goes to the spade connector on the motor in the engine compartment). Ground is through the case/mount-flange (fiberglass tubs not withstanding). To test the motor you can run a couple of short jumper wires from the battery (one from the battery (+) to the spade connector on the motor and one from the battery (-) to the motor flange/case).Make sure to test the ground connection (you can find it coming off the back of the motor on the engine side of the firewall).
Make sure to test the ground connection (you can find it coming off the back of the motor on the engine side of the firewall). If you have power to the switch, you can test the three speed positions by connecting your tester between the female connector at the resistor and any good ground. Each of the 3 female connections should only work in the corresponding fan speed switch position (12v to the resistor no matter what, but the connection position determines the voltage drop --and so speed-- to the blower).
If the voltage is good on any of the connections, then the blower should at least work when the switch is on that position. If it doesn't, there are only 3 possibilities: resistor is completely open (no signal at all coming out), bad ground to the blower, or bad blower.
B2
My duct cables also need fixed - is the general consensus to go with the MTS products?
Yes - those are the MTSHave a look at these, they're priced high but they look like you'd never have to worry about them. Are they the MTS ones you meant?
