I decided to rebuild the Dana300 and upgrade it as much as possible.
NOVAK master rebuild kit
NOVAK ultra short rear output
JBconversions Low Max 4:1 gear set
JBconversions HD Front output shaft
JB Fab Cable twin stick conversion
Taking things apart went better than expected. No issues there.
Changed the springs and detent balls in the shift rails and when sliding the rails back in I pushed one of them in too far and "CLICK "
. The ball popped into the grooves on the rail and it will not budge in any direction. I have tried to push ,pull, twist, etc.. I tried a brass drift and hammer. No luck.
Help!! I am hoping that one of the many JEEP WIZARDS out there might have a magic spell to fix this problem.
. The ball popped into the grooves on the rail and it will not budge in any direction. I have tried to push ,pull, twist, etc.. I tried a brass drift and hammer. No luck.Help!! I am hoping that one of the many JEEP WIZARDS out there might have a magic spell to fix this problem.
