Dana300 shift rail stuck!?!?!?
Cmath
Scrambler Enthusiast
Woodstock
Ga
I decided to rebuild the Dana300 and upgrade it as much as possible.
NOVAK master rebuild kit
NOVAK ultra short rear output
JBconversions Low Max 4:1 gear set
JBconversions HD Front output shaft
JB Fab Cable twin stick conversion
Taking things apart went better than expected. No issues there.
Changed the springs and detent balls in the shift rails and when sliding the rails back in I pushed one of them in too far and "CLICK ":banghead::banghead:. The ball popped into the grooves on the rail and it will not budge in any direction. I have tried to push ,pull, twist, etc.. I tried a brass drift and hammer. No luck.
Help!! I am hoping that one of the many JEEP WIZARDS out there might have a magic spell to fix this problem.:bow::bow::bow:
Have you tried installing the shifter and seeing if the leverage provided by that is enough to move it?
I also remember there is a particular order that you're supposed to assemble/ disassemble... front in x gear, rear in x gear. My apologies, it's been 15 years since I've had mine apart, so I don't remember the particulars.
Did you reinstall the interlock "pills" as well?
If so, the other shift rod may need to be moved to a position that allows the interlock pill to release the stuck shift rod.
If the only thing holding it up is a spring loaded detent ball, a good whack with a rubber mallet should free it pretty easily.
Good luck!
I have not tried using the shifter. Only because I am still waiting for it. I spent the better part of 3 hours trying to free the rail yesterday. I plan on taking a fresh look at it today and maybe catch something that I missed.
Good luck!
Pills are installed. I have the plugs out and the sensor as well .I would think that the spring and ball are just normal position but I can see the ball in the detent and no budge at all. I am going to start with a vice and mallet later today. I will see where that takes me.
you may have to mess around with moving the other rail around, since in some of the positions it will keep one of the pills "out" preventing you from pulling it out
That's what I am thinking. Hopefully it's the pill holding the rail in because of the other rail being oriented a particular way. I did speak with someone who received the wrong size(smaller) detent balls and the smaller size made it so that the ball would not roll out of the notches. He had to drill and in the end needed a new rail housing . Hopefully not the case here.
With a lot of twisting turning wiggling shaking etc. I managed to get the other shift rail loose and from there was able to remove the other rail. 2 things
1.Small piece of debris that looks like part of a detent spring.
2.Smaller detent ball on top of the spring
In the end success .
Thanks for the suggestions!
