- charlotte
- nc
I finally got around to doing the nutter bypass. I now have MC2100 and all unnecessary vaccum lines, etc. removed. I am now working on cleaning up and removing the wiring associated with the computer. Working backwards from the computer plug and diagnostic plugs, I have been tracing and then removing each wire. I am down to the last few and unsure what to do about the remaining wires. Hoping someone can answer these questions:
1. What is the white relay located on the passenger side? it has a white and black wire that splits and goes to the computer and the diagnostic plug. It also has a red wire that goes to the 6 pin connector. And it has a pink wire goes to the small plastic fuse box looking thing. What is this relay for and can I delete it? Picture attached.
2. There is another white relay towards the center of the firewall. I believe it controls the manifold heater and electric choke. I intend to leave this in place. The choke has a second wire coming out of it that goes to the diagnostic plug. can I simply cut the wire to the diagnostic plug off at the choke? Picture attached.
3. There is green wire that runs from the ignition box (same plug as the orange and purple wires used for the nutter) to the diagnostic plug. This a white wire branches off before the diagnostic plug and goes to the plug at the coil. When I unplug this wire at the coil, the engine will not start. It starts fine when the coil plug is plugged in. I am assuming I can remove the section of wire to the diagnostic plug and make a clean spice from green to white?
4. Should the 6 pin connector remain? The manifold heater/ choke relay appears to be powered from this, but it looks like the other pins can be removed?
5. Can the black fuse box looking thing be removed/ what does it do? It clipped one wire that traced to the computer. the remaining wires go to the 6 pin connector and the relay mentioned above. Picture attached
I appreciate any help.
