- Suwanee
- GA
I replaced my headlights over a year ago with KC Light direct replacements. At the time I had a couple of problems with the grounding. I fixed that issue and had functioning headlights, both high and low beams. I also replaced the bulbs in the indicator lights all around. Everything was seeming working somewhat fine. I had (and still have) an issue of when the headlights are on, the front indicator/parking lights won't flash when I put the turn signal on. The side turn signals flash, but not the front. Also, after trying to align the lights in the light buckets, I don't have low beams. The high beams work just fine, just no the low beams.
Any ideas on some things to look at?
I wonder if I am shorting out the low beams with the headlight buckets somehow, but I don't know.
None of that explains why the front amber lights don't blink when the headlights are turned on.
