Stainless pre-bent brake lines?
Flatie46
Russllville
TN
Does anyone know where I can get a complete set of stainless steel brake lines for a CJ8, with power disk and wide track axels. I've been surfing the web but it seems I find them in either regular steel, or non power or one even said 4wheel drum, which I'm pretty sure they never offered in a CJ8? I'm sure I'm not the only one to search for this?
I got mine from classic tube or inline tube. Same company? Not sure. But I got my brake lines from one and my fuel from the other. But I think they came from the same place with different names. If that makes sense. In any case, they were great. So glad that I did
And you got stainless, for wide track with power brakes?
Why is 82 not in this list? They have wide track axels too.
For some reason when I googled it they didnt show it, guess if I googled '83 it would have come up. Maybe some early '82's were narrow track?
82 must have been a mix match year. Have found 83 gets me where I need to go. Also for what ever reason ebay had Inline tube where it was cheaper than inline web site for stainless with power brake.
Don't do it! I have not been able to get mine to stop leaking!!! Last week I spent 4 hours messing with them and the next day they're still leaking. I've done everything sequestered many times over. I'm at the point where I'm more than likely going to replace with steel and take a loss. Brakes are something not to skimp on (don't ask me how I know).
I
I have used quite a few sets of stainless steel brake/fuel lines from the above mentioned suppliers, never had leaking problems?
What is the issue with them, exactly?
I just installed a pre-bent stainless set from Inline Tube.
I had a few leaks initially, but they went away after re-tightening the fittings a couple of times.
Overall, I'm very happy with the product.
What about a complete clip or mounting kit for the lines? Or will I need to restore what I have?
I
Where are the leaks comming from? Is it one leak or several? I agree brakes aren't something to skimp on but I can't trust a 40yr old steel line, so I gotta do something. I completely replumbed the brake system on my 70 C-10 last spring. Lots of crawling under and out from under it. While the body is off this puppy I'm going to do all I can to keep me off the floor. lol
I got a bunch of the little clips with rubber covers in a pack from Summit Racing when I did mine. Still have a bunch of them. Did not need newely as many as I bought. It wasn’t a kit, but rather a large bag of them.
