So, here is the basic list of what I used. IT DOES 100% work...
-Early YJ clutch pedal along with the support bracket for the firewall. Mine was from an 89.
-Wilwood 3/4" bore Clutch Master to basic off the shelf brake line (don't remember the thread)
-The brake line then connects to a brake hose from a Ford Escape (I think from an 06)
-The Ford Escape brake hose is a decent length and is the correct fitting/thread for the slave
-The slave is from an 89 Mazda RX7
-The mount for the slave can very easily be made from angle iron. Nothing fancy
-Chevy Bell for 11" clutch NOT the bell for 10.5" clutch (VERY IMPORTANT)
-Chevy 11" clutch from 77 Chevy 305 C10 Pickup. It should come with correct throw out bearing (1.25 tall). The spacer plate I mentioned earlier is not needed.
-Pilot bearing/bushing from Novak. There are two available. I needed the inner one even though Novak told me the outer one is what I needed. So measure what you actually have to make sure you get the right one. DO NOT just go by what they tell you.
-Exhaust manifolds from C6 Corvette. (The truck manifolds won't work)
-Shifter from a YJ. I added a little to the top to make it taller just for comfort.
-AX15 to DANA 300 clocking ring (I bought mine on ebay for like $40)
-AX15 tailshaft seal from a 94 V6 Dodge Dakota 4x4. The Wrangler version will NOT work and no, you don't need that expensive double lip seal. The Dakota seal works perfect.
-I mounted the trans using a factory cj mount and bracket. I just simply drilled new holes to match the AX15 mounting holes. I also drilled new holes in the factory skid plate since it is now further back than the T176 that it replaced.
-Obviously you will need your driveshaft lengths changed. I actually used a rear drive shaft for the front and rear. The fatter drive shaft does comfortably clear everything INCLUDING the factory truck oil pan. No need for an F body oil pan.
-There is an oil level sensor on the side of the pan directly in the way of the driveshaft. Simply plug it off.
-Speed sensor, Dakota Digital makes one to go inline with your cable driven speedo. I don't remember the signal it sends but make sure when you send out your computer they change it to match. Believe it or not, I have yet to hook mine up and have had absolutely zero issues.
-Send out your factory computer to turn off the antitheft crap and anything else you delete out of the harness. Any dyno shop can do this for you.
-I used the factory clutch fan, works great. Even with no shroud I have had zero overheating problems in 100+ degree stop and go traffic. I would still highly recommend a shroud though. I have just been lazy and haven't gotten to it yet.
