LS swap radiator and tranny coolers.
Kane
Berlin
ct
I started this thread to talk about cooling choices for LS swaps. What are you currently running on your swap and do you like the setup?
I am at the point of making a decision on cooling the Jeep. I have several three row copper radiators sitting in my basement that I am thinking of using. The only issue here is one of the hoses would need to crossover to the driver side but that is not a big deal. I have been looking at aftermarket and the $500 price tag is just scaring me. On top of that most of them do not have a built in tranny cooler so I will need to spend money on a separate cooler for that.
Right now I am looking at trying my stock style 3 core 350 swap radiator that I already own and then using an auxiliary tranny cooler. I pulled a dual fan setup out of a junk yard last weekend that should work well. I really would like to know if the aluminum ones that are out on the market are worth it.
I'm using the aluminum one for the 258 from radiatorexpress.com. It was around $220. I had just bought it earlier that year but my 258 died shortly after so I thought I would try it. Now I have been running it for several years with zero overheating issues. Even with just the factory clutch fan with no shroud (although I do recommend one to be safe especially in southern states). The inlet and outlets were on the wrong side. Wasn't a big deal, I just looked though the stash of hoses at AutoZone until I found some that would work. I can see if I can find the part numbers but honestly they really weren't that hard to find. If you do that just make sure your hoses are attached in such a way so they won't interfere with anything. I'll snap some pics later today.
The good thing is I am running electric fans so I can more easily clear the hoses from moving parts. The part number would be awesome if you have time to find it. I think my 3 core will do fine since it kept my high compression 327 v8 cool when I had it. I am just getting tapped out budget wise so I need to try this first.
Top hose Dayco 71617
Lower hose Dayco 71903
The top hose I think I had to shorten slightly.
The lower one I cut in half and re clocked it since the angle was wrong. The top of that hose where it connects to the engine I trimmed down a little too. No big deal. I used a pipe in the middle of the lower with a clamp to hold it in place so it won't flop around by the fan. This has worked very well.
The little coolant hoses that go to the throttle body I abandoned completely. They are just plugged off. Even Winter wheeling when the temp was -8 it ran perfect.
PXL_20210215_140442575.jpgPXL_20210215_140501698.jpgPXL_20210215_140453246.jpgPXL_20210215_140512833.jpgPXL_20210215_140526290.jpg
Wow perfect thanks!!! This saves me allot of headaches shopping around. I have heard two sides to the steam port argument. I heard some ditch them and other swear they must stay to prevent air pockets. Right now I am unsure but I an fab something up if I need to add it in.
The steam ports are just not needed in an LS swapped jeep. Reasoning is the radiator is physically higher than the engine. In some applications the radiator is not which can trap air pockets in the cylinder heads. Just as reassurance you can CAREFULLY bleed some coolant out of the port on the engine. Just don't burn yourself! I bleed the system at the radiator first like normal then loosened the plug to let a little bleed out. I doubt it was needed though.
I can just install a purge valve to bleed out the air and check it from time to time. Thanks for the info.
$3 at my local junkyard. I got it out of a late 90s/early 2000s GMC Safari van and used a universal elbow from autozone. I had a K&N style filter at first but was constantly having problems with the oil from the filter getting on the MAF sensor and causing a check engine light. I'm sure there is something out there that would look nicer than what I have but it works.PXL_20210215_195147421.jpg
The picture is deceiving but it does comfortably clear the radiator hose.
On Copper I used a 350 swap style Northern brand aluminum radiator. Aside from a long upper hose, it worked out well and cleared the 5.3 fan clutch. Kept it nice and cool. It also has an integral trans cooler which I ran in series with an aux cooler.
On Red I went with a BeCool Boneyard dual pass radiator. It’s oversized and this is proving to be a pain in the rear to mount up. I had to trim the grille shell just to fit it. It does not have a trans cooler so I’ll be going with a stacked plate aux cooler with a thermostat bypass. I’m wondering if the slightly larger size of the radiator is worth all the extra headaches. But I’m committed at this point.
I would put money on it that your air is cleaner than most aftermarket setups to.
What is the bypass for? It is to help the tranny heat up quicker?
Yep! It snows here...not that my Scrambler will ever be on the road in the snow...
So I bought these hoses and the top hose is very small in diameter and the bottom one needs another 12 inches in length. Did you use two different hoses for the bottom one?
The top one fit the engine decent, but I had to stretch it a little to get it on the radiator. You can kinda see that in the pic of my upper hose.
As far as the lower hose, the Dayco 71903 hose is for sure the one I used that attaches to the radiator. That was the one that was a little more of a pain to figure out. I thought it was just the one for the lower but I probably did use another hose that goes from that middle lower pipe up to the engine. Sorry, I don't have a number for that one. But at least it shouldn't be too difficult to find. It was in stock at AutoZone. That info got lost when the site crashed.
When I get home later I'll see if I have any pics of the hoses/part numbers on my old phone.
Its fine really. I appreciate any help. The top one I just bought a speedway motors inline steam port adapter and it goes up in size to fit the radiator so I have that part covered. If you don't find it do not worry, I will just head to Napa and size one up. You got me very close as it is.
