This is a manual transmission. Not sure about the CA thing. My son got it from a women out of Seattle. How can you tell?
I installed the O2 sensor in the existing port just after where all of the exhaust comes together but just before the connection from the manifold to the exhaust pipe.
Sounds reasonable. Are you going to plug the pulse tubes? I doubt if you want those connected if you are still running a cat. The AFR should be correct with the EFI as is, Also i doubt the EFI will like the additional air coming in downstream .
The Holley Sniper Forum is a good reference.
