- Charlotte
- NC
Yep, direct fit, remove factory panel, replace retainers and screws that come with kit.I assumed that, just curious as to if, for your application, any mods were required. Seems like it was a direct fit, which is nice.
Did you have the wandering before the lift/tire upgrade?Solved the JL wandering with Synergy Steering box brace.
Not a lift and tire issue… Seems be a design issue with steering box, newer JLs have improved cast box, but there is just enough flex to wander… three JLs in our family and we have done all three.Did you have the wandering before the lift/tire upgrade?
We are awaiting a new JLU 4xe and was wondering if this may be something we might need to do.
Thanks.
Had that debate, owned the CB and have handheld GMRS… likely switch out as some of my trail friends switch…Why a CB and not GMRS? Haven’t used my CB in a couple years now.
Firestik gave some nice antennas for the SOA National raffle and everyone that ended up with them offered them up saying “anyone running a CB?”
Did that fix it? I have the cast gearbox in my JT but it still wanders now and then. I was looking at the Steer Smarts Yeti XD brace.Solved the JL wandering with Synergy Steering box brace.
I think it has improved wandering more than the Teraflex front track bar and steering stabilizer installed earlierDid that fix it? I have the cast gearbox in my JT but it still wanders now and then. I was looking at the Steer Smarts Yeti XD brace.
Also what did you use for this? I've already had small chunks of gravel from the roads I use stuck in there.Foam tubing keeps debris out of gap between body and fender flare.
