Pics request-t176 mount
matnic
Scrambler-in-Progress
Rapid City
I am switching from a SR4 to T176, and I just wanted to see where yours goes. More specifically, I would like some pics of the trans mount and the skid plate. I know there are 2 sets of holes in the skid and in the bottom of the tranny, so I just want to get everything put together and ready to go in quick once I have it in the air, since its just me putting it in with a floor jack. I don't want to have to muscle this around alot and have to fiddle with which holes are used!
Thanks!
Mat
p.s.
If you can't post them here, please email them to: nicholson@torchlake.com
I can do that....
I'll get some this evening when I get home....You just want a pic from underneath showing how/where it all bolts up?
Pretty much. I am just not sure which sets of holes to use, both in the skidplate and in the transmission itself.
Thanks!
this should do it..
There are 3 sets of mounting holes on my skidplate...My 83' with a T-176/D300 uses the center set. You results may vary....but shouldn't....Hope this helps.
Hi all, bringing this old thread back...just switched from a SR4 to a T176 and nothing aligns....a few questions
1) All 258 engine brackets are the same, regardless of the transmission ? (I feel like my engine is sitting very forward)
2) With the T176, the tranny pan is bolted in the forward holes or rearward holes ? In the most forward holes the pan sit too wide for the chassis.
3) With the T176 what holes you use for the tranny mount ?
Thanks in advance
Post #249, from a long time ago, might help on the skid plate to fame bolt holes:
IIRC, the T176 uses the forward 3 sets of frame holes for the skid plate to bolt to. The pictures linked to above will show what holes in the skid plate to use.
After that, bolt the mount to the transmission, and it should align with the correct mount holes in the skid plate.
Post #1088, also old:
Looks like I used the center or rear most holes in the skid plate, depending on if I was running the T5 or T176.
To make it 100% bolt on, you will need:
1) The T176 floor plate
2) The T176/Dana 300 combined shifter boot
3) The T176/Dana 300 reverse light/4wd indicator wire harness
4) The Dana 300 shifter that was used with the T176 (different then T5 version)
I'm also swapping a T5 for a T176 and wasn't aware of any differences in the D300 shift lever. Is the T176 specific style required, meaning there will be interference using the shifter from the D300/T5 combo?
The Dana 300 shifter handles are bent slightly different to fit through the OEM tunnel cover/shifter boot(s) correctly. I would guess a T5 Dana 300 shifter would work, BUT will not fit through the OEM floor plate/boot correctly :shrug:
I imagine it could be heated and bent to fit? I will see if I can find a picture.
Quote from me, back in 2012 when I swapped in the T5/removed the T176:
"There is a difference between the Dana 300 shifters used behind the T176's vs the T4/T5 version. My T176 Dana 300 shifter hits the rear of the floor cover plate hard, and will not shift into 4 Hi. It would be very difficult to bend it to clear, and make it still look decent. It would require so much metal trimming to work that the boot would no longer cover the hole, either. I am currently on the hunt for a T5 Dana 300 shifter handle."
More information:
🤯 Good to know, thanks. I have a replacement tunnel cover and boot for the T176/D300 combo so I'll see if that works with the OEM D300 shifter. If it doesn't I'll try and find the correct shifter or bend the one I have to fit. Sorry if this was a thread hijack...
