Under floor support replacement
Dallas
New member
Wever
IA
I am working on a 83 cj8. My question is I am doing a full restore on the tub.but it has the good ol midwest cancer in it. I'm looking for suggestions or ideas on doing certain parts ..
First thing...to do the floor traverse support and other parts like it should I just set it on its side or upside down or what...
Rotisserie is a no go....dont think it will stay perfectly straight until all major under supports are fixed
After the major underside is done I can set it on a good frame for a jig
I'm not interested in buying a whole new tub either...I have plenty of welding experience from my daily job....plus growing up in a fab shop besides I enjoy making it new again
Have you seen this:
I think the addition of bracing is the key before removing the frame or other supporting structures. :shrug:
The frame was junk...it was bad enough it was sagging in the middle..
Understand, I saw you were a new member (Welcome :thumbsup:) and was just trying to give you some information to browse while waiting for more knowledgeable input.
Craig (certifiablejeep), as well as others are well versed in the procedures necessary.
I did mine on the sides - if you have a flat floor and some 2x to keep it off the bumps at the rear arches etc you should be able to get to both sides easily. Just roll it with care - need about 4 people.
Best to weld some angle first across the top of the doors so that it keeps it's shape, (measure first to ensure the tub isn't off square)
. Others put diagonal bracing in as well
Downside vs a rotisserie is it means more hours as you cant get to places that are next to the floor, but mine would not have survived a rotisserie without substantial bracing that would have made it difficult to work on.
One of the advantages of a CJ - all the sides are flat - so easy to fixture from a floor.
Mine wont take the rotisserie either....my sides buckled too from the frame being shot...so I'll have to figure that part out gotta rebuild the sides anyway....but floor first
Is the frame still under the body? If there are still body bolts intact and doing their job you could jack the frame back and get the body back to position. My frame was total junk as well. An old Franklin skidder pulled it about 500 yards to the road. I straight edged my sides and then ran angle iron down the top sides right to the A pillar then cross braced. The body is pretty forgiving. My2C.
My thinking on this is you need body to mount on a new frame. Get new frame, put body on it with doors lined up, move around until all bolts line up, cross brace as suggested and take apart to flip and fix bottom supports. @certifiablejeep has a lot of experience with tubs, might search his threads for ideas.
I would think if you could put this on something flat... floor/frame/jigged up cart and then you can straighten it out, fit doors like mentioned above... once it is back to "flat", cut the rear floor and then put a new one in. It is a lot of prep work, but without it, you will be chasing fitment areas all over.
No body is off the frame
Got any pics of your process
Front supports need done too....I have a perfect frame to use for a jig.....traverse...
