- Ashburn
- VA
Hotwire Auto in Arkansas.where do you send it to? im interested in doing the same for my scrambler
Yep. That was a nice surprise when I showed up. Along with the warn 6 bolt hubs and a spare to go with them.Nice find. Looks like HD tie rod and drag link also.
I assume so. It has to be better than the 3.31 with the 35sYou will luv the 456 gears
You’ll love 456. I’m running 456 on my 44/30 combo, as well as ARB’sI assume so. It has to be better than the 3.31 with the 35s
I had a Spartan, but turns out it was for an HD 44, so I ordered a TORQ locker last night. So it will reuse the carrier.What locker are you going with? You only need to match gear backlash and have appropriate carrier preload into the case if you are using the same gears with a carrier swap. You just need to measure backlash prior to disassembly.
Those shock tabs are really nice. We use them here on almost every Jeep build. I am planning on getting some to use on my front 44 once I get some high clearance u bolt plates. Only thing to watch is the eye to eye length of the shock at ride height. May have to move the shock tower to match.
Lol. Lockers good.
What exhaust are you running?
I've been battling that drone through three different mufflers. Probably tried that same Magnaflow before the Cherry Bomb I have on there now (it's chambered and actually better!)
Think there's going to have to be an additional resonator of some sort.
Had one, its guts were rattling, it's gone. That's why I assume I need a resonator of some flavor.Are you running a cat? Even just a cheap high flow helps fight the drone a lot. I'm definitely going to put one back in when I redo my exhaust. I was definitely surprised by how much of a difference it made.
