FLCJ8
- Palm Bay
- FL
I'm cleaning up for our move and figured I would check to see if anyone has a use for some of these parts before they go to scrap.
I had discovered that some items I had tossed out were actually sought after so I wanted to avoid that situation again.
FROM CJ5 (unsure of year, PO converted to 4 wheel disc)
1 set of 11" front backing plates and drums
1 set of 11" rear backing plates and drums
Rear fixed bench seat Honey(?) color (frame appears rusted as mounts are loose)
Has a tear in the corner of the top, not sure if someone may want the cover for some recovering project
(I'll post a pic, if anyone has an interest, once I remove some other items.
FROM '83 CJ8
1 set of 10" rear backing plates and drums
1 set 5 bolt front hubs
1 set 5 bolt OEM lockers
2 sets 2.73 carriers and R&P gears
3 rear OEM two piece axle hubs
All these parts were functional when removed for upgrading.
The parts are located in central FL (32950) and most would need to be picked up due to weight
FROM '83 CJ8
