1985 cj8 Build / Restoration Finally
nib
Well-known member
Gold Member
Hernando
FL
Hey folks this build has been a long time waiting. Purchased around 2002 In really good shape I ran it for a couple years.
Story:
1) Found 8 at jeep dealer 2002
2) The dealer had installed Howell throttle body conversion, Front spring reversal, Ranchero spring lift / shocks 2-3", 1" body lift, 4.10 gears, one-piece rear axles, New basic seats and center console. front and rear heavy-duty bumpers, steel 20 gal+ fuel tank, steel black multi spoke wheels and 31's.
3) After I purchased, I found the 4.10 with 31" to be a little short (no real highway stuff but anything over 65 mph she sounded stressed). I Changed to new wheels and 33"s and a tach (not in dash) installed Melling's high volume oil pump, electric rad fan, and Hei distributor. Worked well BUT. The aftermarket springs and shocks were to stiff
4) At this point I'm sure you're asking WTF is your problem.
5) Short answer gearhead (if you don't have at least one vehicle on jack stands you ain't trying)
6) I decided she was a perfect candidate for quick rebuild. Sold interior, springs / shocks, wheels and tires. Disassembled to bare frame and sand blasted frame. THEN.
7) Well, At this same time I was working on a 86 Jaguar xjs v12. Been restoring / building British cars for 30 years.
8) So I set the jeep aside to fix the jaguar. That was 15 years ago. Good news is the jag has been totally redone (to what I thought a proper GT should be).
Any way before I do any painting or treating of the frame my question to you folks is. Are there any spots or areas of a scrambler frame that could use some attention or are the frames good the way they are?
One other item. I found this the other day. The pics look better than it really is. 20 years tied to a trailer in Florida. SHE IS ROUGH Frame rotted; body rotted, v8, bed floor cut out. I think back many years ago someone probably made it for mudding. Just wanted to see if there was any interest.
PIC 2
The main places to watch on the frame are around and in front of the rear wheel arch. The inner frame C will also rust more quickly than the thicker outer portion. The 8 on the trailer will also be a good place to look for areas of concern.
We probably also need some pictures of the Jag.
Thanks for the info. The frame on my 8 has no rust at all. I had it sand blasted to inspect welds and recoat with a encapsulator type product.
Jag pics
Jags just don't look right with the steering wheel on the wrong side.....
That Jag is pretty darn neat. The electrical system on the 8 will be rather boring in comparison.
Oh, my good man I cannot wait to be bored. The jag build has been a blast. Really frustrating at times to try and understand the reasoning. Then that's why I removed all wiring and stared over. Installed new circuit panels to handle loads and fuses. They tried to do their best to be modern and cutting edge for the time.
On this 8 build I want to try and stay in bounds. Just update what needs to be. New wiring harness (this time I probably won't build my own) 4-wheel disc brakes, OME springs, 4-liter head on 4.3 block, The Rino lining thing. I think it's great idea for a lot of jeeps out there. BUT I don't think I'll go down that road. I want sound deadening but liner is so permanent. I think I will strip, and paint then go with sound proofing (mat type) and carpet for me. Then If / when it's sold the next owner can adjust to his taste.
Input is always welcome Thanks
4.0 head on 4.2(typo obviously)Had me thinking for a second you were gonna swap a 4.3 chevy V6.
Sound deadening mat would probably be bad if you ever get stuck in the rain without a top or door. Wet carpet is bad, mat would be worse, water can't evaporate through it like carpet.
Stock 1985 block (just trying to come down from a v12 hangover). Have heard 4.0 head works well. Will probably contact Titan since they are super close by for more info. And the mat thing. I'm not sure if I agree. The mat that I have used on my other project is asphalt based this shit ani't absorbing nothing. Carpet yes. There lies my quandary. I guess maybe go with paint / floor mats and a big stereo lol.
Example. Back a while I use to customize flats boats here in Fl. Powder coat was the rage. Very nice BUT. It is basically a coating and when you breach that coating with a counter sink or fastener this allows moisture to enter causing ugliness.
The mat won't absorb it but just keep it under it and prevent drying. I know some is adhesive backed but I am sure water would get under it. I have no experience with it in a Jeep, just my truck that doesn't get water in the cab.
I had rubber mats in the floor of my tan CJ7. While I was off at school the seals on my steel doors let water in, which then sat under those rubber mats, so now I need new floor pans in the front.
With bare paint it would have evaporated and probably been fine.
CJ's are loud @nib. Sound deadening isn't going to do much when you look at all of the sources of noise.
I like OEM carpet, but only on a garaged rig. It's easy to take out if it does get wet, and it does offer a little noise deadening. The more you put in the floor, the harder it is to take out if it does get wet.
Thanks for the input. I think I will probably paint the whole tub original color and if I want to put in carpets that can be removed in the event of water.
