- Hernando
- FL
Hey folks this build has been a long time waiting. Purchased around 2002 In really good shape I ran it for a couple years.
Story:
1) Found 8 at jeep dealer 2002
2) The dealer had installed Howell throttle body conversion, Front spring reversal, Ranchero spring lift / shocks 2-3", 1" body lift, 4.10 gears, one-piece rear axles, New basic seats and center console. front and rear heavy-duty bumpers, steel 20 gal+ fuel tank, steel black multi spoke wheels and 31's.
3) After I purchased, I found the 4.10 with 31" to be a little short (no real highway stuff but anything over 65 mph she sounded stressed). I Changed to new wheels and 33"s and a tach (not in dash) installed Melling's high volume oil pump, electric rad fan, and Hei distributor. Worked well BUT. The aftermarket springs and shocks were to stiff
4) At this point I'm sure you're asking WTF is your problem.
5) Short answer gearhead (if you don't have at least one vehicle on jack stands you ain't trying)
6) I decided she was a perfect candidate for quick rebuild. Sold interior, springs / shocks, wheels and tires. Disassembled to bare frame and sand blasted frame. THEN.
7) Well, At this same time I was working on a 86 Jaguar xjs v12. Been restoring / building British cars for 30 years.
8) So I set the jeep aside to fix the jaguar. That was 15 years ago. Good news is the jag has been totally redone (to what I thought a proper GT should be).
Any way before I do any painting or treating of the frame my question to you folks is. Are there any spots or areas of a scrambler frame that could use some attention or are the frames good the way they are?
Story:
