drscanman said:
...but should I do it again, I will save for buying a custom built harness from Hesco. The input and threads from cjoffroad where important reference.
I have been watching this posting and based on my experience, a lot of good information has been posted. I did the 4.0 HO/AW4 swap eight years ago before the cjoffroad.com site existed. There was plentiful information on the web then about the 4.0 swap but none on the AW4 side of things. I was lucky to find a 92 XJ with 62k miles that was totaled, which I salvaged out. I did not even know about OBDI versus OBDII issues until reading cjoffroad.com.
I agree about the Hesco wiring advice but the last I knew, it did not accommodate the AW4. You might want to check that out. Other things you need to be aware of are that the AW4 is about 5” longer than the T4/5 and the 999. (I can not find what your current tranny is.) This means accommodating in some way that the stock t/c linkage will be 5” back. I ended up modifying a Currie twin stick. While you can use the stock skid plate modified, you will not realize the clearance gains until you have a custom skid plate.
You will have to fabricate transmission cooler lines and have a transmission cooler. I placed a cooler in front of the radiator and then eventually put in a three-row radiator with transmission line connectors and now use both. If I had it to do over again, I would buy a cooler with fan motor and place in the area under the battery tray and eliminate the long lines, etc.
Another item that took a lot of time was the transmission shifter. Nobody that made custom automatic shifters at that time, such as Lockar, could tell me if it would work on an AW4. They would just say buy it and try it. I do not know if this has changed or not. I ended up building a custom console that accommodated the XJ shifter and linkage. This took about three versions over a couple of years to get one that looked appropriate.
I have been very happy with this swap/conversion once I got all the issues fixed. I took me about a year to get it working the way I wanted but answers to most of my issues are now on cjoffroad.com. I am curious to know why Novak was critical and I will check out their web site.
On the 4.0 part of the swap from an XJ, there are a few other issues, which are well covered at cjoffroad.com.
Later, Ken
