Won't start
Update: I was, manually, able to get fuel through the pump. I believe that narrows it to an issue between the tank and the pump.
What do you mean by "manually"?
Give us a little more info on the steps you took and where/how far from the pump you got fuel.
We'll be happy to help with steps to narrow down the most common issues.
Sorry. Hand actuate the pump. From gas can into the pump then out the otherside into a plastic container.
Okay.
Have you tried to reinstall the pump and test with the same set up (the gas can and plastic container) to confirm the pump was installed properly.
You want to confirm the pump works installed before looking to the fuel lines/tank.
Can you blow air into the line that feeds the pump? As in, blow air into the tank? With the stock setup you should be able to blow into the line with LOW pressure 5 psi max and hear a gurgling in the tank.
99b16e88-d219-418b-ba7b-c1679e065024-jpeg.94709
Here is what the fuel pickup looked like in what I thought was a good tank.
Modern fuels are horrible.
Okay.
I did prior to this test without success. I will try that again. Should that not work, it would tell me that I'm putting it in wrong. Then I'll go from there.
Thank you for your help.
Update to the update: She runs!! I appreciate everyone's help. I swapped out fuel pumps again. New Delphi replaced with USMW. Initially, i ran a line from a gas can into the fuel pump. After that worked I hooked up the regular fuel line from the tank. And, with great nervousness, it worked!
Thank you all again.
That's ugly. Do you know if there is a better fuel pickup that would be more conducive with today's fuels?
