Shackle Replacement
STSFCTN
Well-known member
Silver Member
Centennial
CO
I had a bad rubber bushing in my front stock shackle and recently replaced my front and rear shackles with the MORE kit with the grease fittings. It did lift the suspension about 1/2 an inch and I did have to recenter my steering wheel. I called MORE and asked what torque settings in the bolts and they said to snug them to the shackle and the bushing, but not too tight.
Prior shackle, I felt comfortable at 75 on the highway, Now 45 is loose and uncomfortable. Basically feels like slop in the steering. Should I just crank them down or is there something else I am missing?
Bushings do need to be replaced occasionally depending on use and wear. New ones may restore your handling
If you dont already know, tighten it all up fully with the weight of the Jeep on the springs as well so its all in its natural rest position.
