My brake pedal sits significantly higher than my clutch pedal. I'm guessing the scrambler had manual brakes at birth and someone converted it to power brakes but didn't do the pedal assembly along with it. Any suggestions? The pushrod linkage has adjustment, but is tightened all the way down and the pedal is still really high. I could try to saw off the end of the pushrod and get more out of it, just not sure if that's the best option. the booster is new-ish, so does anyone know where to get a pedal to booster pushrod that is shorter
