Just got a 1981 CJ-8
Ifster
Member
White Rock
NM
Hi All.
I've been looking for over 20 years and just got one. It's all original. 4.2L, auto.
I spent a few days messing with the electrical and got it running. Engine runs great, so for now I'm not gonna do a V8 swap, unless a 360 falls in my lap. PO installed a new transmission just before parking it.
For now the plan is to get it on the road.
Every freeze plug is leaking, except the one in the back of the head, so I'm not going to pull the drivetrain as I had first figured. I'm sure the head plug will leak soon and then the drivetrain will be removed and I'll go through it. I've removed the left fender and the grill to get access to the core plugs. I will be removing the intake and exhaust manifolds also.
Question for now if what do I need to do to take the slop out of the column shifter. I can't find any of the gears and it just moves up and down without any noticeable engagement in any gear.
Thanks
More than likely the plastic bushings in the linkage. There are 3 or so spots where a rod fits into a plastic bushing that attaches to another rod. These can wear out or be missing developing slop.
I had to replace all of mine in my shift linkage. I found that these from rock auto work the best. They are currently out of stock, but maybe you could find the same brand elsewhere.
Welcome to club! Anything you need to know, you will likely find it here.
Great, I'll look for those.
Thanks
There is also one that goes in the steering column where the linkage snaps in. It’s a larger hole. I haven’t been able to find a good replacement for that one. If anyone on here knows of one, let me know.
The loose shifter arm on the transmission wasn't helping the matter at all. That's tight now and seems marginally better. Still waiting for the bushings.
I noticed the kickdown lever bushings are all rotted away. I crammed in one I had as a spare from my JK T-case, but it's not gonna hold, can't get the E-clip on the kickdown rod to hold it all in place. I could trim the bushing and likely make it work. But if the right one is available I'll do that. Anyone got a line on those.
Thanks again.
