- Molalla
- Or
I started this during the summer. I cut the front of a CJ7 frame and the back of a CJ8 frame and had my neighbor weld them together. Twelve inches were added to the wheelbase. You can see there is a long space between the body mounts in the middle of the frame. I had the frame sandblasted and I primered and painted it. I bolted the motor mounts for the Chevy engine in place. I've had those for years. I figured they would work for the LS3 as well as the older generation engine. If I'm wrong, someone let me know. Springs are for two and a half lift. Figured I'd need a little more ground clearance for the longer wheelbase. I got it this far and put it in my little garage for the winter. Now that I can post pictures, I'll be able to show progress from time to time.
