- Charlotte
- NC
Thanks, the tent and rack are about 300 pounds…Nice setup. Do you have an estimate on weight for just the top and your tent setup ? Not all the items you are adding, but where you are on those 2 items.
I recently found this brand… https://skinnyguycampers.com/models/truck-campers/5-0-glr/I’ve been looking a little online at a couple of other brands. Four Wheel Campers and Topo Toppers.
37” with 3 liftNicely done! How much lift and what size tires?
@rubclt what paint did you use on the battery box when you painted it? It looks to be "textured", could be a 1/2 hardtop paint option on the 8........? Thx for the reply!Adding a power bank with Redarc 1250 charger, 1500W Inverter and 200Ah Lithium Battery with Self-Heating.
To house all this in front of bed required welding two battery boxes and finish with Bedliner.
View attachment 117603View attachment 117604View attachment 117605
It’s Raptor Liner from a can. It’s tricky the first time so suggest practicing. Unlike rattle can you hold it 24-36” away. A thin coat top coat with black would work on hardtop. It needs top coat as no UV in Raptor Liner@rubclt what paint did you use on the battery box when you painted it? It looks to be "textured", could be a 1/2 hardtop paint option on the 8........? Thx for the reply!
The "press break" I see in the background of the first picture, how functional is it and are you happy with it?If the queen is happy there is piece in the kingdom. Keep this in mind as you see this mod…
View attachment 119874View attachment 119875View attachment 119876
It’s helpful for small bends, use occasional. This is one at link: https://www.amazon.com/dp/B0BXNB5FQJ?ref_=ppx_hzod_title_mob_b_fed_asin_title_0_0The "press break" I see in the background of the first picture, how functional is it and are you happy with it?
Thx
Thanks, the 200ah battery is key with 1500 Redarc Inverter. It really allows new way of camping with electric when there is no shore power, which is normal for our travels. Starlink mini and it’s just like being home.Looking better equipped than the AirStream I might add!
