100 day summer rebuild
Question: Does your welder operate with shielding gas? If so, did you do the welding outside? The reason I ask is it looks as though you were having a hard time laying a good bead. Welding outdoors is difficult because the breeze will blow the gas away from the weld and not allow it to do its job. Also, prep time is actually about twice as long as the actual welding. I use a flap wheel on a 4" grinder to do it, but you need to come up with something to remove the scale from the material to be welded, this is true even in the materials were purchased new, you have to get them clean (DO NOT USE BRAKE CLEANER!!!).
Dont give up on welding if you enjoy it. 6 years ago I made an investment in a nice welder, with no clue how to use it. I have a few friends in the fabrication business for race cars and such, so I would weld up scrap in the garage and send them photos, they would send back responses of what adjustments to make. Now that I have the basic knowledge and can see good vs not so good welds, it is actually my favorite thing to do in the shop.
The reason i can't use stock cross member is because the 360 sits about 3" further forward with intern moves the transmission forward. The cross member is no longer underneath the drive train mount. The previous set up used the stock cross member but because the frame tapers, underneath the transmission, the cross member because to long to mount directly to the frame. The previous owner had the set up shown below.
As for the welding, I'm using a miller 211 with flux core and 110V. There are two fabricators in my neighborhood who have been teaching me to weld.
Obviously is all of you think that the new cross member is unsafe something needs to be done. I’m curious to know how other people with 360s have felt with this problem.
Do you think it would be possible to weld some plate to the bottom of the of the cross member that I made in order to strengthen it ?
[/URL][/IMG]
You have a decent welder, but I dont think you are making the best use of it. Ditch the flux core and get some gas on that thing then hook it up to some 220V. I have worked with a 110v mig, and I think it is OK for light sheetmetal work and maybe a repair here and there, but for structural welding, it is just not going to cut it. You need more heat (more power), and to take advantage of all the welder has to offer.
What frame holes are you using for the motor mounts? I have a 401, a 360 and a 304 and they all rest on stock skid plates with small modifications to fit the T18 in 2 of the cases... the 360 has a 5 speed in it.
I know that the 6 cylinder used certain holes for the motor mounts and the 304 used different ones... and t hey both used different motor mount adapters to the block.
Take a picture of your setup and I can try to snag one to show you what I mean.
Day 65:
I made the cross-member today and put in the brake lines
[/URL][/IMG]
Since you are asking... here is what I think.
First off. Take the time to get your pieces cut to the right length. If the piece is too short, DO NOT fill the gap with welds. Not only does it look like sh!t, its not strong AT ALL. (as it looks like you did on the closest weld in the picture, front driver's side)
If you cut the piece WAY to short, DO NOT cut a short piece to extend it, same reason as above. (driver's side rear)
The trans mounting part. Those 2 square tubes that you used... if you are taking the time to fab up your own mount, make it out of one piece or at least cut the two pieces the same length.
If your welder can use shielding gas, throw the flux core crap in the garbage and set your welder up for gas.
Again, I'm not trying to be a d!ck, just trying to help you become a better fabricator and welder. TAKE YOUR TIME!!! dont use scrap pieces of metal you have kicking around to make something that will just be OK. Prep your pieces. TAKE YOUR TIME!!!
Frame holes to the right of the shock... this was when the 6cylinder mounts were in there... notice stock trans crossmember.
Custom motor mounts for adjustability up/down left/right in the bay, but they are on a 401 and still on the stock crossmember, just notched for the T18 wider berth on the bottom
I guess the obvious question I didn't ask was what tranny are you running, I can't remember.
Also, there are holes on the bottom of the frame that allow you to move the trans cross member up or back... I would have to see which holes on that were used.
I don't seem to have any pictures of the 304 install, thought I did... have to look some more.
Here is the last one of the 401 going in...
PS> The 6 and the 8 sat in the engine bay about the same... you had mentioned moving it up 3 inches... would you have clearance issues with the fan and radiator then?
I'll send pics tonight also of my 360/tf999 with oem skid
Yes, OEM skid... final thought on this... do you have a skid for a dana 300 setup or a earlier model one for a Dana 20 setup... I had this same issue when trying to do this...
You said the drivetrain was swapped in, but that T150/Dana 20 setup (if this is what you have) came from an older setup... if he kept the "stock" crossmember, it might have been for a Dana 300 setup... your picture tipped me off with that droop.
THATS IT!!!!!!!!! THAT IS EXATLY I HAVE EXCEPT WITH THE DANA 300 CROSSMEMBER
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Why flat. Single Stage urethane from Eastwoods will fit the bill just the same and last for a very long time. It will go on just as easy and has good fill. I have single stage on my CJ5 for 20 years and all i need to do is apply Armor All paint protector on it each year.
I say mainly flat 'cause it also doesnt show errors in the body work nearly as much. Its a good thing to do until you see what it takes to get shiny paint to look good. And moreso I said flat 'cause his cost and schedule risk ratings are nearing red and I want to see his performance risk low to increase his smile factor.
Days 66-67:
paint tomorrow
looking for and older crossmember, PM if you have one...
I have several and you are welcome to one, but shipping would be very costly. I'll send a PM to the Adams in Kansas, they should have one. :wave:
Day 70and 71:
Only 20 more work days!
gas lines are in more paint
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
