1942 GPW
Putzing around with the GPW when I got home today. Mounted replacement marker lights, attached the fenders to the grill so I can remove it all as one unit, installed headlight buckets, and added a blackout light mount to the fender. It was not one that was on this GPW originally, and the light is not correct, but that can be rectified later. I also attached the hood to the tub. May not stay attached, but there it is for now.
Have not done much recently, but in preparation for moving the tub to a different spot and moving the rolling chassis around, I needed to remove the flat tire. So I put on the chrome wagons from the Scrambler. It rolls around a lot easier now. The front wheels would not fit over the hubs. So it looks really odd right now. 🤣
Looks great out in the light. These rears are 235/75 (29”). I am sure I could fit 31s easily. And 33s with a small lift. Can’t wait to make real progress.
Since I am focusing on getting the Scrambler ready for wheeling season, I am slow on the GPW. I need to set the tub on its side and start foxing the floor. And clean the frame up and strengthen it. But that was not on the cards this weekend. So I cleaned the windshield. 🤣
You can barely see the shattered glass on the passenger side now. (Jk)
I have pulled the cage back out in prep of pulling the body back off. I may not use that cage or may alter it. I have time to decide on that.
It has been quiet as I have been focusing o the Scrambler. Today I picked up a gas tank from a 2a that I will get cleaned and sealed to use in the GPW. It came with 4 NDT tires I won’t use and a grill screen for a 2a/3a I won’t use.
Soon I will start to clean up the frame.
Made a little progress. I had to go get my hoist from my son’s place (i thought he would be using it before me so let him store it in the barn at his rental). And decided I have to get that motor out if I want to make any progress on cleaning and prepping the frame. Now I have to get serious a out picking the drive train. I am thinking 4.3L Chevy v6 with SM 465.
I am also wondering if I should save any parts from this motor as spares for my 3a before I sell it.
Yesterday I removed a lot from the frame including the battery tray, trans mount, shocks, motor mounts, and a metric ton of grease/dirt. I also sanded it down again since it got flash rust and I did not get all of the nooks and crannies before. Then put a coat of primer on it. Will need to apply some good paint soon as well. The front bumper is mangled up. But I am leaving it there for now to help keep the frame square and I don’t want to trip over it for now. Eventually it will be replaced with a stout bumper of some sort.
Picked up a 4.3L v6 for it last night. It was free. Hopefully it is a decent motor. Will start the process of tearing it apart to see.
I get the idea of bigger is better, but I just love the sound of those little go devils.
We have a 3a thats stock. I do like the little go devil. I do not want to rebuild the one tat came with my donor frame. And honestly, for this build, I want to be able to go faster than 45mph every once in a while.
