2000 XJ Question---Off topic
Stouttrout
Registered Jeep Nut
Sour Lake
Tx
Well, with a family on the way I am looking for something a bit more Family friendly. I found a good deal on a very nice XJ. It has 8 inch rustys off road suspension lift,15x10 weld racing rims, 35x12.50 tires. It has a 4.0 in it. Anything I should look for? Would make a decent family wheeler? Has the stock axles still but I will probably swap them out. :D
try jeepforum
or the other XJ sites.
There quite a few in our club that wheel pretty hard. They are very durable. I have heard many mixed things baout the Rusty's lifts. Mostly good on qaulity and very bad on service.
That is huge meat on stock axles. Does it have the 44 rear? If not that might be your first upgrade.
If you want a good family friendly rig, may I suggest a CJ-8. :D Raise the back seat up 3.5" and even an adult can fit back there with ease and comfort. Trust me, I have as much back seat time as my kids.
Three years ago, I wanted an XJ for to mod for exploring. After I brought one home to show my wife for permission to buy, she saw how small it was and told me "NO." She convinced me to look at a ZJ which I had mentioned. The back seat has much more space than the XJ which makes it a truely family vehicle. After another week of searching, bought the first one I test drove. Did a 3.5" lift and put 31" tires on it. Because of the coil suspension, did amazing things wheelin it though will say nothing over a moderate trail. Was still very comfortable on the road for my DD.
Trick if you do look at a ZJ is to get one with the 4.0 engine and tow package. This will give you 3.73 gears and u-joint style front axle and drive-shaft. This should also pretty much guarentee you the select-trac transfer case (2H-4HF-4HP-N-4L) which is suppose to be better.
As far as the 35" tires on stock XJ axles, you can do it fairly easy. We have a couple of guys running TJs and XJs like that and only one has broken so far. Of course, the guy that did break has had to replace the rev limiter a couple of times because he's worn it out. If you do break an axle shaft, just upgrade it to the alloy shaft and you should not break it again.
Just remember, both the XJ and ZJ are unibody construction and thereby will flex more. This will read to additional creaks and moans as you wheel it. I think they make excellent moderate and below trail rigs, but will have a short life span if you wheel them hard. Have heard the XJ as being a disposable body, you wheel it til the hatch and doors don't close any more than you throw it away and get another one.
I love our XJ and plan to build it moderately for family wheeling when it is retired from DD duty (long time though). Mine has 114k on it and I would very seriously drop in a "crate" stroker motor at the first sign of engine trouble because I really think that the running gear will last a very long time.
Then if the body goes, get another one, swap any lift/tires and engine over and keep on going.
You can certainly build the snot out of an XJ for relatively low cost and spare stock stuff is SO easy to come by. Lee's brother Jamie (wyndzer on here) has a NICE XJ built about like your looking at. His is on a Skyjacker lift IIRC though. There's pics of it on here and it can wheel with anything similarly equipped.
With XJs (and ZJs) you have to keep in mind the issues if you damage the body seriously....
I'd be all over it if I were you... you are at the top end of the stock axle strength, but if you keep that in mind you should be ok. Just carry spares of everything.
I tried to convince the Mrs. on another CJ8 but she just is not comfortable driving one. On this one she needs to be comfy in it. She will taking it to work some. I really don't do heavy trails and I am just looking for a good light trail rig. I may in a few years do anothe hardcore, all out rig but With the baby on the way and it bieng our first, I have change routes. Heck, I have jump completely ff the track I was on, Spun 180*, landed on another track and am now picking up speed. Geez, I hope the bridge isn't out :D . Well I ought and I will pick it up this week. Here is a pic of it.
Not to rain on your parade, but.......
Your wife is going to hate you if she needs to use something that tall to move your newborn around in. My wife hated having to "climb" in and out of my stock 3/4 ton Burb when putting the kids in their car seats. Not to mention all the crap you have to drag around, load and unload, with kids.
Now if its just a toy, get on it!
Oh No, It will not be our main vehcle. We have a stock 2wd rodeo and Suburban. However, With my Line of work i have more free time than Her. I will be Mr. Mom. :eek: I will be hauling the stuff around much more than she will be. So, from time to time she will take the XJ to work with out Junior.
Just to know that it was asked: that has been geared appropriately for those tires, right?
I'd assume as much, but just wanted to be sure. My 235s are manageable and 31s would be as high as I'd go with stock gearing...
Nice looking rig. Tires are a little wide for my tastes, but I like the stance. (EDIT: I just saw that you mentioned they're 12.5, sure look wider to me, maybe it's just the very square shoulder.)
Not sure of the Gears. He said it will cruise at 70 with no problem. I see an Axle swap in its near future anyway. I am getting pretty effiecient at those :rolleyes:. What I will probably do is locate a set of axles and take it to Texas Auto gear and say Here -- Gear it, lock it, and mount it up. The tires are dunlop muds and I am not too hip on them. They work till they wear out though. I am in it pretty good and may just get it back here and put it up for sale but the looks are growing on me and I think with a set of D44 under it that are built it should do good.
So, should I be looking for a set of axles from an 80's Jeep Cherokee?
Cruise at 70 sure, but after 5 minutes to get there??? ;)
www.NAXJA.com
All you want to know about XJs and more!
The Chrysler 8.25 isn't too bad as rear axles go from what I've read, but there's lots of 44s under XJs.
Something to ask about/look for is the rear driveshaft. For that much lift they HAD to do a SYE kit and you should have a CV rear dshaft.
In looking at that front side picture, it almost looks like a stock steering setup. With that much lift I'd think the stock steering setup would handle real poorly.
Also check the way that the trackbars were lowered. Sometimes people try some very sketchy things to get around paying for/installing proper drop brackets. You want that front trackbar to be parallel to the drag link for the steering to eliminate bump steer. Hard to see that level of detail in the one picture...
Let's say lots of mods. Stabilizer on the draglink indicates they had problems and put a band aid on it. I know there will be tons of bumpsteer with the draglink at that much angle. Hard to tell from the picture, but it looks like the shocks will limit the droop of the axle, so it will need a limiting strap which I don't see. You've already mentioned tires, lockers, axle, etc. Do you really want to buy a vehicle where part of what you are paying for are the mods and the mods weren't done to your liking or properly? Were the rear spring hangers reinforced to handle the added lateral stress from the lift?
It is fairly inexpensive to lift a Cherokee several inches so would it be cheaper to buy a stock one and build it the way you want it?
Have you asked why the guy is selling it? Doesn't handle well, poor fuel mileage, breaking parts, built just for show?
Have you put a child seat in the rear facing backwards? Kids love to ride and be jostled to sleep so make sure you get one that they will fit in.
Not sure of your finances, but do you have the necessary cash flow to do what you want with the vehicle along with all the medical bills, savings for braces, college and such? Do you already have the money set aside for bills in case you are your wife can't work for several months. From other post, seems like you are pretty smart in the finance departmet but wanted to ask.
Not saying you shouldn't do it, just playing devil's advocate. Maybe I'm too practical or getting too old, but just doesn't seem like a good choice for a family man with newborns.
The dragink is a definate issue to be addressed. However, the price is justifiable. He says that it drives very nice but before he added the Stabilizers on the steering it did have a slight bump steer. No has none. He thinks it has 3.73 gears. The idea was to use this for trail riding on light trails. He said the original paperwork list a towing package on it but he was not sure what that included. I am not either.
I doubt it would be cheaper. I ran the figures quite a few time. Maybe I should ask this, Knowing that 35's and AA rims will set you back at least $12-1500+ and that a Rusty's long arm 8" kit cost around $1700 and knowing the vehicle is in top running condition and mint shape----What do you think It is worth? NADA says an average of about $10,000 and that is including the hit for miles. What do you think would be a reasonable price for this truck?
I have seen baby seats in the back of then and have a freind who owns a 2wd. she has 2 kids that have been practically raised in one. Our baby has a nice Suburban or rodeo to ride in. It will probably ride in that most of the time. This purchase is more to please the wife. She is not to hip on the CJ7. Loves the 8 but does not want another. She has been talking about them since we went to the National Event. She really like the one that belong to Lee's brother, or father. Not sure exactly but I have the right family :D Then we went to the Big Hooters Event and she eyed a white one there. She mentoined several times that it would be nice to have. I think the fact that has AC is a BIG factor.
I really would be interested to know what you think one like this would be worth? If anyone has any idea let me know. :D
How many miles are on it?
I assume you're going to get a test drive on this thing. You'll know if the gearing is off immediately. With 3.73s I'd think it would be a pretty good dog on 35s. It sounds like he didn't actually do anything with them so just be ready.
That does look like a stock steering setup, I bet the bumpsteer is AWFUL. The good news is that you can get a better and HD setup for not much. Actually, looking closer, it doesn't look like he did a drop pitman, that would help some right there.
I'd stick around the NADA. You can't add the cost of the mods new to the bluebook and expect to get all of that back. Especially if you can cite a couple of things like the stock steering with no drop pitman and the gearing that you'll have to change (he doesn't need to know that you're wanting to swap axles). Also ask if it's had a recent alignment (many people don't bother after doing a lift). If you can, pull the front tires and check the pads rotors too, easy thing to point out that might need replacing.
FWIW, we've had our babyseat in the XJ and it fits fine. Ours is destined to be the family truckster so we knew to try that out first thing. I think you're a lucky man to have a wife interested in a built XJ like this! :D
I think, like you, that anything that's really wrong with it is easily fixable (as long as there's no hidden sketchy booty-fab we can't see) and cheap. If the engine and tranny look/feel good to you, I'd be all over it.
Figuring 50K miles and SE package with a few upgrades like PW, PDL, Cruise, Tilt, cloth seats, etc, and allowing for outstanding condtion, edmunds.com only gives a dealer price of $9,880 and a private price of $8,434. Of course, you need to compare these numbers with what is actually being sold in your area, look at autotrader.com for a good comparison of stock vehicles. You can add a few hundred dollars for the lift and tires but that's it, exactly how much you add is dependent on you. You should already know that you don't get money back for mods. Usually, a modified vehicle will actually bring less than a stock vehicle, mainly because it severly limits the demand.
With 3.73s and 35s, it will definitely be nailed to the pavement. My ZJ, though slightly heavier wasn't peppy with the 3.73s and 31s but was bearable. So gears or axles will be a must.
With a trackbar at that angle, stabilizer or not, it must have bumpsteer. Even with only a 3.5" lift on stock steering, I had bumpsteer.
Suggest before you contemplate farther, you take it for a test drive and make sure you find either a good dip or rough railroad track.
It seems like it will do what you are wanting it to do. If its a price you and your wife can afford and willing to pay, then its reasonable.
how many miles?
I have seen a number of simlarly built XJ's going in this arear for about 7500 to 9000 in that age range. The most expensive XJ I have seen was 11K but it had 25K miles on it.
This is just me, but I just would never buy a lifted vehicle. You just never know who did the lift and what short cuts they took. Also I am the kind of guy (and I get the feeling you are too) that likes to pick out each part I put on my rigs.
The amount of lift seems like overkill for a 'light trail rig.' A stock XJ with a little lift and 31's will not only drive very nice but will also be a great light trail rig. For the money, you could get a ZJ which is way nicer inside and with much nicer ride. I could not see my wife driving that rig to work. She loves Jeep's but that is overkill for her.
Just sharing some thoughts, if that is the right thing for your family then grab it, it looks pretty cool. But like many things, looks are not the whole package.
I have always found edmunds to be a bit low for this area. I watch alot of vehicle run through. I have been watching these for about 6 months. I hit auto aucttions on a regular basis and almost Bought two. I used to be a buyer for a dealership. The two I almost bought went for more than this one. I am well below the prices the mentioned here. I am headed over later this week to get a better look at it and drive it.
Just alittle about me since some don;t know. I see the finance thing has been brought up a bit here. Serioulsy, Thank you for the concern. More should worry about that and have concern for others in that area. I have always been an over planner when it come to finances. I started saving for retirement and seriously plannng for it when I was 23--Ten years now. So, I wouldn;t ever do something that might put my family in a crunch. And, I would strongly suggest that anyone that has not started saving do so know. This country has a horrible problem right now with debt and when this bubble pops, and it will, it always does, big trouble will hit. Okay, off my soapbox. :rolleyes: This topic can get me going pretty good.
