2005 Jeep LJ "Slow Roast" build (just another LJ on 1-tons)
So it gives extra clearance when simply mounted in place of the stock skid or are there other mods required to get this on? :fingerscrossed: :drool:
This made me think that there should be a "body lift skid" setup for those that add a body lift such that it moves the whole tank up accordingly. I know you didn't add much BL , but it's typical to do a 1" or so for folks not going with the highline setup or cutting sheet metal (like me!). Never seen anything like that...
Yeah, Eric. It's supposed to give 1" more clearance underneath with a minimum 1/2" BL (from the ground), and 1" behind the differential. We didn't measure behind the diff, but it sure looked close to 1". It's definitely a nice piece, fit like a dream, and gave me some extra clearance when bolted in the stock position. It's a WIN-WIN-WIN. :)
Craig
AEV front flares installed...sexy! The rear flares will require extensive body cutting/grinding before mounting.
PSC hydro assist bling!
PSC steering box installed.
Thanks to Gordon at RockSolid for hooking me up with a used Warn winch plate, and 8274 winch! I'm very excited, as I hadn't given much thought yet to a winch choice. (I'm getting one of the two 8274s shown below.) The winch plate will likely be blasted/powdercoated before mounting.
Gordon at RockSolid making quick work of my rear spring bucket removal. Gordon also grinded them clean-'n-purty in about 5-10 minutes (something that quite literally would have taken me 1 1/2 hours, because I'm so anal-retentive about it...LOL). I told him I don't know whether to thank him, or be pissed that his skills are so much better (faster) than mine.
Hydro assist eh? Plan on doing much road driving with it or is it strictly off road with it now? I remember people having stuff going wrong with full assist while driving down the road. Is assist the same way or is that still road legal in MI?
Kevin
Kevin
Hey Kevin. Good to hear from you. Hydro assist IS road legal in Michigan (I wouldn't have done it otherwise, and can't justify an off-road-specific vehicle). It's full hydro steering that you often see on off-road only rigs. Hydro assist actually gives very nice road manners with "one finger steering", but it still has the mechanical linkage with the drag link & tie rod (RockSolid actually does a hydro assist set-up that doesn't use a tie rod, but that's not the set-up I'm using).
I actually didn't know much about it before I got the 37" tires; there wasn't a need to. :) I understand that some people run the stock steering box with tires this big, but from what I hear, the steering is considerably tougher, and the stock steering boxes tend to wear out. The RockSolid guys have run 37" tires on several of their rigs, so they're very familiar with the necessary (or ideal) hardware to do so.
Mine will definitely still be driven on the roadl. I can't wait to get it off road, but am equally as excited to just cruise around town in my Jeep again.
Are you going to be at Jeep Blessing this year?
Craig
Hi Craig,
Thats great to hear that it is not going to be an offroad only vehicle. The CJ-7 needs a battery and some freshening up this spring as it has been off the road for a couple years now. The postal needs a different motor again. I am at a loss as to where to bring them. We haven't decided as to what to do with the postal motor route. Today I am leaning towards getting a crate or rebuild 4.2 and changing everything off the current postal motor over to it. I am tired of it being under powered though. not being able to go up test hill stinks
Got any people in the area that you trust with that kinda thing?
Kevin
Winch plate is now powdercoated.
Components for flush-mount rear receiver hitch (Thanks Mike @ RockSolid Performance).
I have a Rokmen flush-mount rear bumper on order, but need a 2" receiver hitch to pull my military trailer (the Rokmen bumper doesn't have one). I carefully cut a hole in my rear crossmember, did some careful trimming back behind, and RockSolid built some adding bracing for the 2nd-to-last crossmember. The plate behind the 2nd crossmember (facing the front of the vehicle) is the secondary towing support. The U-shaped plate facing rearward will be welded in to help index the tub in the correct position, and provide additional vertical support. The 2" receiver tube will be trimmed down to fit, and will be welded to the rear bumper when it arrives. The tube will slip through the hole in the rear crossmember, and will bolt to the 2nd crossmember. The hitch pin hole will be drilled between the two crossmembers.
From the back side of the 2nd crossmember (plate will be welded in place).
I had a pleasant surprise tonight when I showed up at RockSolid Performance... The guys had my gas tank reinstalled, along with my new Rokmen skid. They also got the rear suspension & axle reinstalled, and made mounts to utilize the stock rear sway bar.
This is precisely why my LJ is at their shop. Were it not, you'd be looking at lame incremental Jeep updates for another 18-24 months. :rotfl:
Advance Adapters HD SYE & Parts Mike pinion brake were also installed. The transfer case also got a new 38T speedometer gear, which should keep the speedo accurate.
The LJ is coming along!
First of all, the used Warn 8274 will be getting a brand new cable, along with a new 4.5-hp. motor. Based on its reputation, it should give me many, many years of trouble-free service.
The skid plate & long arm brackets are now powdercoated & installed, and the control arms are 75% painted (stealthy black). The stuff is looking much better now! I'll be finishing up the control arms tomorrow night, with the exception of the upper fronts, which will be painted after the steering/track bar set-up is designed & built.
I started test-fitting the Rokmen aluminum corner armor, along with the AEV rear flares. The flares will be painted the same silver body color (hood & front fenders are going into the body shop tomorrow to start being cut in). We were strategizing (I'm copywriting that word...LOL) on how to trim the corners to accommodate the flare without a gap at the transition to the body. We think we have a solution. More to come.
Still thinking it'll be good for the Jeep Blessing? Thinking about coming up for that in my LJ. :D
It'll be tight, but I'm being told it'll be ready. I just dropped off the AEV fenders/hood at the body shop today. Shoot me a quick note if you'll be at the blessing, and I'll keep an eye out for you, Eric.
Craig
Hood & fenders are at the body shop getting the OEM silver paint cut in. (no pics).
The first hole I ever drilled in the body of my Jeep (4/21/2012). "The first cut is the deepest."
Rokmen aluminum corner guards installed.
The Rokmen aluminum corners will be trimmed to fit tightly to the AEV flares. Passenger-side AEV flare is now installed (driver side to be installed tomorrow).
Repainted front & rear driveshafts and control arms reinstalled.
The new track bar bracket, compliments of Mike at RockSolid Performance.
Front axle at full stuff.
The new roller fairlead. There's just enough room for a small RockSolid Performance sticker above it.
End of day (Saturday) beauty shot. I love the look of the installed rear corner guards (which will be painted the body color) & AEV flares.
Nice! I'd sure be tempted to leave the flares black myself, that's a killer look! :drool:
Biggest upgrade of the day...a RockSolid Performance sticker. LOL
I got the driver-side AEV fender flare mounted up this morning.
Some TLC with a few 4 1/2" grinders got me this on the driver side (carefully ground to butt up to the back of the AEV flare).
And the passenger side...
Passenger-side fit against the AEV flare (first try). A slight amount more trimming, and I'll be all set.
Steering Rev. 3.2.6, or as BJ at RockSolid Performance said, "Version 65.7.3 Rev. 2" (or something like that). This is the final design, and everything clears beautifully. Thanks beejers!
we installed Dodge 2500 master cylinder to manage the additional volume of the 1-ton brake calipers. It's almost a bolt-in upgrade. It requires a longer pedal plunger, some proportioning valve trimming, and some very minor bending of the brake lines.
New Bilstein shocks. Blingy.
Rear shocks & shock mounts w/integrated skids mounted on the back of the LCA mounts. Nice work, RockSolid Performance.
Passenger-side OEM Rubicon rocker guard install (driver side still needs to be installed). I bought them 3 weeks after I bought the Jeep in 2005, and they have been in a box ever since (I was too much of a wuss to drill holes in the body). I've moved on.
Full stuff. Some minor trimming was required on the rearmost edge of the wheel opening. Not too shabby for 3" of lift.
The Jeep sitting back on its own weight again.
The Jeep on its way to get its new exhaust. Next week, it's going in to get the hood/fenders painted to match. It's getting close. I love the stance, too!
forum
