2007 Jeep Wrangler
I don't think those pictures have anything to do with the real vehicle. It might be a current Wrangler stretched over the new chassis. I also think there's some wrong info in the article. I read earlier that the standard Wrangler would be a 96" wheelbase. 101" seem a little long, but I guess that's possible, but 138"!? That is a full size, extended cab pickup truck. That must be the optional Wrangler "Prom Limo" package.
what he said
I think I agree. The top doesn't even fit!
I think I heard that this is actually just a pieced together frankenstein to test the drivetrain changes.
I don't think you read the articles closely enough Scrambler81. I remember them saying there would be the new Wrangler, same basic width but slightly longer wheelbase. However, it also said there would be a 4 door vehicle with 6-inch wider stance and greatly widened wheelbase.
I think that the spy photos do have the new front clip on it which has a more sloped hood. The hard top is obviously short, probably from an '05 Unlimited.
That's why they're called spy photos.
Well, I'll believe it when I see it. 138" is longer than a Ford Excursion. The wheelbase on Jeep's new 7 passenger model is only 109". I understand they are making it bigger, but that seems a little extreme.
EXTREME! WooHoo (where is the Homer icon when you need it)
I don't think so
I just got back from the 4 wheel jamboree here in Fredericksburg, Tx. and was in touch with a local co. called whatajeep that stretches TJ's to 4 doors. They had contacted Chrysler to verify if they had plans to make a 4 door wrangler. A Chrysler rep. mentioned that it was not possible at this time. The way they built their manuf. line was pretty limited and therefore the unlimited is the longest vehicle their line can support/fit. The cost to make a line to support a longer vehicle would be too much (at this time) So maybe the wheel base can be moved back a few inches and a 4th door (small) can be squeezed in but I doubt it. Anyway my 2 cents.
BTW on another note I saw 2 scramblers at the event as well as a few unlimited here is the link to my coverage of the event ...O'Reiley's 4 Wheel Jamboree in Texas (txtrailriders.com)
Well, my Chrysler guy is in tomorrow, so I plan on doing a little pleadin' and beggin'. Don't know how much good it'll do, he's not always real loose with the info. But I will give it one heckuva try. ;)
ttrdiablo said:
I just got back from the 4 wheel jamboree here in Fredericksburg, Tx. and was in touch with a local co. called whatajeep that stretches TJ's to 4 doors. They had contacted Chrysler to verify if they had plans to make a 4 door wrangler. A Chrysler rep. mentioned that it was not possible at this time. The way they built their manuf. line was pretty limited and therefore the unlimited is the longest vehicle their line can support/fit. The cost to make a line to support a longer vehicle would be too much (at this time) So maybe the wheel base can be moved back a few inches and a 4th door (small) can be squeezed in but I doubt it.[/URL]
That is the point of the article that they are moving to a new facilty. So with the new plant they can pretty much design it anyway that they want. Once the new plant is on-line and working they plan on mothballing and demolishing the old plant.
Sad to see a lot of history go away, But I guess that is what you get with Diamler/Jeep.
The new vehicle could be good or bad. I am just hoping that they put the CRD in the 96' TJL before they end of life it. That would be what I really want. But I am not getting my hopes up. They will probably save that for the new chassis. But this is my own opinion.
Carl
a couple years ago at the Detroit auto show, Chrystler had a 4 for door prototype that was actually very cool looking. Aside from the top not fitting and all the previous post mentionings (word?), the thing that makes me not believe the photo is that it says its a "4 door". Where are the other two doors. Underneath? On top?
Things that make ya go HMMMM!
They won't all have four doors, but there will be a four door option. The way I understand it, the new one will look similar to the Gladiator concept (the front end).
CBRogers said:
[...] I am just hoping that they put the CRD in the 96' TJL before they end of life it. That would be what I really want. But I am not getting my hopes up. They will probably save that for the new chassis. But this is my own opinion.
Carl
Carl,
What's this CRD to which you refer? :o :confused:
CRD / diesels
CRD refers to DC's diesel engine.
What will it take to get more diesel options from DC in America? You can get the Liberty in diesel. Why not the TJL? There are so few diesel options in the US. It seems VWs and large trucks are the only diesels you can find. No mid-size SUVs or light duty trucks.
I'm becoming more interested in running biodiesel ....
I'm not an expert on diesel engines (no duh!) but I think it has something to do with the quality of diesel fuel in America. Once it catches up to the fuel available in Europe, I believe you will see a lot more diesel-powered vehicles. BTW, there is a good chance you'll see it in a GC soon. Haven't heard anything about a TJ though. The second factor is supply and demand. I think most american's still think of diesels as being dirty, loud... They don't know that many of today's diesels run nearly as quiet as many gasoline powered vehicles. And also run nearly as clean. A lot of PR still needs to be done.
I would agree that the biggest problem is with American's perception. The quality of diesel fuel is improving in America...but even as it stands it's still a better alternative to gassers. My wife and I are in the market for a new VW diesel and have driven a couple and you can't even tell a difference in sound, power, etc... Not only that...but diesel engines do burn cleaner than gassers. A buddy of mine was an engineer testing pollutants in the exhaust of huge generators that move gas all over the country. They hooked the testing equipment up to his Dodge Cummins dually diesel (of which he has installed several aftermarket accessories to make it faster and more performance) and it scored lower on I think all levels than the Civic that another dood had rented for the week. Include that with the fact that the VW diesel cars are getting 45+ mpg conservatively (some reporting 55+ with a few upgrades) and you have quite a case for diesel being a leader in alternative fuel vehicles. But it would definitely require a major shift in perception in America.
It'll be interesting to see which way the future-fuel debate goes. I hate to say this (being a Detroiter and all) but I think the long term priority is to eliminate the need for fossil fuels, and maybe even internal combustion, altogether. That's why hybrids are getting all of the play.
I agree :( ...once againe it's all about perceptions. It's amazing what a little education could do for this country. But oh well. The manufacturers aren't going to make any kind of drastic push or change until the market does something about it. We still drive our H2s and huge behemoth vehicles everyday to work and back and have not cut back on our driving with what gas prices are doing. I would imagine even if they went to 5 bucks a gallon there would still be very little change in actual vehicle usage.
The flip side though is that if we begin to drive more efficient vehicles and are making less trips to the pump...that means lower tax revenue for the state and we'll start seeing other ways of being taxed to increase that level. I mean it's a Catch 22 for everyone. There's a lot to this debate that we just don't see.
